メインコンテンツにスキップ
Acer Aspire V5-591G-75KE Wireless Card Replacement
必要な工具と部品
  1. Acer Aspire V5-591G-75KE Wireless Card Replacement, Acer Aspire V5-591G-75KE Disassembly: 手順 1、 3の画像 1 Acer Aspire V5-591G-75KE Wireless Card Replacement, Acer Aspire V5-591G-75KE Disassembly: 手順 1、 3の画像 2 Acer Aspire V5-591G-75KE Wireless Card Replacement, Acer Aspire V5-591G-75KE Disassembly: 手順 1、 3の画像 3
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Wireless Card Replacement: 手順 2、 2の画像 1 Acer Aspire V5-591G-75KE Wireless Card Replacement: 手順 2、 2の画像 2
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Wireless Card Replacement: 手順 3、 2の画像 1 Acer Aspire V5-591G-75KE Wireless Card Replacement: 手順 3、 2の画像 2
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Wireless Card Replacement: 手順 4、 3の画像 1 Acer Aspire V5-591G-75KE Wireless Card Replacement: 手順 4、 3の画像 2 Acer Aspire V5-591G-75KE Wireless Card Replacement: 手順 4、 3の画像 3
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
  5. Acer Aspire V5-591G-75KE Wireless Card Replacement, Wireless Card: 手順 5、 1の画像 1
    • Locate the wireless card on the top left quadrant. It should have two antenna cables connected to it, one white and one black.
  6. Acer Aspire V5-591G-75KE Wireless Card Replacement: 手順 6、 1の画像 1
    • With a pair of blunt tweezers, firmly grasp each antenna head and detach it by lifting straight up.
    • The antenna cables are connected through small sockets. Small popping sounds when attaching and detaching the antennas are normal.
    • Note that the white cable connects on the top socket.
  7. Acer Aspire V5-591G-75KE Wireless Card Replacement: 手順 7、 2の画像 1 Acer Aspire V5-591G-75KE Wireless Card Replacement: 手順 7、 2の画像 2
    • Using a Phillip Head size 1 screwdriver, remove the screw attaching the wireless card to the laptop frame.
    • To detach the wireless card, lift up slightly and pull away.
終わりに
作成者
2人の作成者と共同で作成されました。
Tasier Hagler
メンバー登録日: 10/18/17
428 ポイント
4のガイドは作成済み
チーム
UW Tacoma, Team S3-G5, Liner Fall 2017 UW Tacoma, Team S3-G5, Liner Fall 2017人のメンバー
UWT-LINER-F17S3G5
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 1,230
