メインコンテンツにスキップ
Acer Aspire V5-591G-75KE Power Jack Harness Replacement
必要な工具と部品
  1. Acer Aspire V5-591G-75KE Power Jack Harness Replacement, Acer Aspire V5-591G-75KE Disassembly: 手順 1、 3の画像 1 Acer Aspire V5-591G-75KE Power Jack Harness Replacement, Acer Aspire V5-591G-75KE Disassembly: 手順 1、 3の画像 2 Acer Aspire V5-591G-75KE Power Jack Harness Replacement, Acer Aspire V5-591G-75KE Disassembly: 手順 1、 3の画像 3
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Power Jack Harness Replacement: 手順 2、 2の画像 1 Acer Aspire V5-591G-75KE Power Jack Harness Replacement: 手順 2、 2の画像 2
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Power Jack Harness Replacement: 手順 3、 2の画像 1 Acer Aspire V5-591G-75KE Power Jack Harness Replacement: 手順 3、 2の画像 2
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Power Jack Harness Replacement: 手順 4、 3の画像 1 Acer Aspire V5-591G-75KE Power Jack Harness Replacement: 手順 4、 3の画像 2 Acer Aspire V5-591G-75KE Power Jack Harness Replacement: 手順 4、 3の画像 3
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
  5. Acer Aspire V5-591G-75KE Power Jack Harness Replacement, Power Jack Harness: 手順 5、 2の画像 1 Acer Aspire V5-591G-75KE Power Jack Harness Replacement, Power Jack Harness: 手順 5、 2の画像 2
    • Locate the power jack harness on the upper left quadrant of your device.
    • Note where the power jack harness connects to the mother board of your device.
  6. Acer Aspire V5-591G-75KE Power Jack Harness Replacement: 手順 6、 1の画像 1
    • With a pair of blunt tweezers, push on the side tabs of the connector to disconnect the harness from the motherboard.
  7. Acer Aspire V5-591G-75KE Power Jack Harness Replacement: 手順 7、 3の画像 1 Acer Aspire V5-591G-75KE Power Jack Harness Replacement: 手順 7、 3の画像 2 Acer Aspire V5-591G-75KE Power Jack Harness Replacement: 手順 7、 3の画像 3
    • Using a Phillips #1 screwdriver, remove the single 10mm Phillips Head screw located on the hinge.
    • Wedge the spudger tool below the hinge, and lift only enough to get a grip with your fingers.
    • Use your hand to lift the hinge the rest of the way to avoid damaging your spudger tool.
  8. Acer Aspire V5-591G-75KE Power Jack Harness Replacement: 手順 8、 2の画像 1 Acer Aspire V5-591G-75KE Power Jack Harness Replacement: 手順 8、 2の画像 2
    • Wedge the spudger tool below the port harness head, and lift straight up until the side tabs clear the channels on each side.
    • There is a piece of tape holding the power jack harness in place, which will give you some resistance. Prying through this tape will not damage the harness.
  9. Acer Aspire V5-591G-75KE Power Jack Harness Replacement: 手順 9、 1の画像 1
    • Lift to completely remove the rest of the power jack harness out of the casing.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Reina Godeck
メンバー登録日: 10/16/17
741 ポイント
5のガイドは作成済み
チーム
UW Tacoma, Team S3-G5, Liner Fall 2017 UW Tacoma, Team S3-G5, Liner Fall 2017人のメンバー
UWT-LINER-F17S3G5
4 メンバー
18のガイドは作成済み
3 件のコメント
Thank you so much! Just fixed my finance’s computer using these directions and I’m a hero!
Amanda M. - 返信
Okay, so I did fix this… But after we booted up the sound stopped working. I was very careful, but maybe knocked something? Any suggestions much appreciated.
Thank you
Amanda M. - 返信
Check the step where you open the case. There is a cable you need to remove thats holding the case to the laptop. Just link that back to where it was and it should work
hrstg -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 1,458
