メインコンテンツにスキップ
Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement
必要な工具と部品
ビデオの概要
  1. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Bottom Cover: 手順 1、 1の画像 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 手順 2、 1の画像 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 手順 3、 3の画像 1 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 手順 3、 3の画像 2 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 手順 3、 3の画像 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 手順 4、 1の画像 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Cooling / Fan System: 手順 5、 2の画像 1 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Cooling / Fan System: 手順 5、 2の画像 2
    • Disconnect the Fan cable.
    • Remove the three screws from the CPU cooler and one from the Fan module.
    • When you change the Cooling system, you must clean the processor from old thermal compound and put new.
  6. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 手順 6、 3の画像 1 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 手順 6、 3の画像 2 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement, Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 手順 6、 3の画像 3
    • Use a lint-free cloth to clean the old thermal compound.
    • If the thermal compound is solidified, you can use a flat end of any plastic tool to scrape it off.
    • Use again cloth with isopropyl alcohol to clean the Thermal surface.
  7. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 手順 7、 3の画像 1 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 手順 7、 3の画像 2 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 手順 7、 3の画像 3
    • Remove the 3x Phillips screws and open the Fan case.
    • Use a soft brush and clean the Fan and the Cooler.
  8. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 手順 8、 3の画像 1 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 手順 8、 3の画像 2 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 手順 8、 3の画像 3
    • Use the same technic to clean the surface of the processor from the old thermal compound
    • Be carefully,if you don't want to break the CPU.
    • Dispense a small amount of thermal compound and gently smear it over the entire processor surface.
  9. Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 手順 9、 2の画像 1 Acer Aspire V5-572 CPU Maintenance and Thermal Compound Replacement: 手順 9、 2の画像 2
    • Careful install the Cooling system with even pressure from all sides, and the bead that you placed on the surface will spread over the entire contact surface.
終わりに
作成者
3人の作成者と共同で作成されました。
ZFix
メンバー登録日: 12/09/13
191,308 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,535のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 18
今までの合計 3,161
