メインコンテンツにスキップ
Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement
必要な工具と部品
  1. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement, Battery: 手順 1、 1の画像 1
    • Use the pointed end of the spudger to slide the battery lock until the battery pops loose.
  2. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 2、 2の画像 1 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 2、 2の画像 2
    • Slide the battery out of the battery slot.
  3. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement, Keyboard: 手順 3、 1の画像 1
    • Remove the two 6mm PH1 screws from the bottom of the laptop.
  4. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 4、 1の画像 1
    • Use the spudger, push the two tabs, located in the battery slot, through their slots to release the keyboard.
    • Do this with the computer slightly open for ease.
  5. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 5、 2の画像 1 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 5、 2の画像 2
    • Open the laptop.
    • Start top of the keyboard and use the opening tool to pop the remaining tabs around the keyboard loose.
    • The keyboard can be flipped onto its face once removed.
  6. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 6、 1の画像 1
    • Use the spudger and slide the grey tabs on either side of the keyboard wires away from the white plastic.
  7. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 7、 1の画像 1
    • Disconnect the keyboard by pulling the blue tape on the wire strip.
  8. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement, Hard Disk Drive (HDD): 手順 8、 1の画像 1
    • Remove the five 6mm PH1 screws beneath the keyboard.
  9. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 9、 2の画像 1 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 9、 2の画像 2
    • Use the spudger to pop the gray tab up and away from the far left wire strip.
    • Disconnect the wire strip by pulling the blue tab loose.
  10. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 10、 2の画像 1 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 10、 2の画像 2
    • Use the spudger to pop the white tab up away from the wire strip located at the top left corner of the mouse pad.
    • Disconnect the wire strip by pulling the blue tab.
  11. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 11、 1の画像 1
    • Close the laptop.
    • Remove the remaining 18 6mm PH1 screws from the bottom cover of the laptop.
  12. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 12、 3の画像 1 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 12、 3の画像 2 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 12、 3の画像 3
    • Use the opening tool to separate the back of the laptop from the inside cover.
    • Open the computer and remove the inside cover.
  13. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 13、 3の画像 1 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 13、 3の画像 2 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: 手順 13、 3の画像 3
    • Lift the HDD out of the base and use the opening tool to disconnect the HDD from the motherboard wire.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Lakbira Sheffield
メンバー登録日: 01/29/18
673 ポイント
4のガイドは作成済み
チーム
University of Alabama, Team S2-G7, Bedsole Spring 2018 University of Alabama, Team S2-G7, Bedsole Spring 2018人のメンバー
UA-BEDSOLE-S18S2G7
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 17
今までの合計 548
