はじめに
Step by step guide showing how to replace the CPU fan. This should help prevent the computer from overheating and randomly shutting off.
必要な工具と部品
Use the pointed end of the spudger to slide the battery lock until the battery pops loose.
Slide the optical disc drive out of the slot to disconnect it from the motherboard.
Unscrew the main 3.5mm PH1 screw from the motherboard.
もう少しです!
終わりに
