メインコンテンツにスキップ
はじめに
This guide will show you step-by-step instructions for replacing the display assembly. Removing the hard drive is not necessary, step 6, for completing this task. Also, make sure the unit is powered down before performing any of the following tasks.
  1. Flip laptop over so that the back is facing upward.
    • Flip laptop over so that the back is facing upward.
    • Push switch to the right.
    • Pull battery away from the laptop.
  2. Use a #0 Phillips head screw driver to remove all of the screws.
    • Use a #0 Phillips head screw driver to remove all of the screws.
  3. Flip laptop back over.
    • Flip laptop back over.
    • Open the laptop.
    • Wedge a prying tool between the keyboard and laptop body seam to remove keyboard.
    • Be careful not to bend the keyboard too much or break the tabs that connect the keyboard to the laptop.
  4. Gently lift keyboard.
    • Gently lift keyboard.
    • Disconnect keyboard from the laptop.
  5. Use a prying tool to remove the upper cover.
    • Use a prying tool to remove the upper cover.
  6. Locate the hard drive.
    • Locate the hard drive.
    • Lift the hard drive.
    • Disconnect hard drive.
終わりに
ある他の人がこのガイドを完成しました。
Joe Niu
メンバー登録日: 2017年09月20日
598 ポイント
5のガイドは作成済み
チーム
University of North Texas, Team S5-G1, Thomas Fall 2017 University of North Texas, Team S5-G1, Thomas Fall 2017人のメンバー
UNT-THOMAS-F17S5G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 331
