メインコンテンツにスキップ
はじめに
This guide will show you how to replace the display assembly of the Acer V5-571-6889 laptop. The display assembly will need to be replaced if the laptop screen is cracked, damaged, or just not working properly. Some common problems include a flickering laptop screen or completely blank screen.
Before getting to work replacing the display assembly, it is important to make sure that the display assembly is the cause of the problem. A laptop screen will also be completely blank if there is a power failure causing the laptop to not turn on. To verify this is not the cause, try to listen for a whirring sound, meaning the hard drive is spinning. Also, check to see if any other lights on the laptop are lit. For more information on troubleshooting, this link provides a detailed guide:
++Acer Aspire V5-571
It is important to note that the replacement of the display assembly is moderately difficult. To ensure no damage is sustained, carefully disconnect cables and verify that the power is off before beginning.
  1. Flip laptop over so that the back is facing upward.
    • Flip laptop over so that the back is facing upward.
    • Push switch to the right.
    • Pull battery away from the laptop.
  2. Use a #0 Phillips head screw driver to remove all of the screws.
    • Use a #0 Phillips head screw driver to remove all of the screws.
  3. Flip laptop back over.
    • Flip laptop back over.
    • Open the laptop.
    • Wedge a prying tool between the keyboard and laptop body seam to remove keyboard.
    • Be careful not to bend the keyboard too much or break the tabs that connect the keyboard to the laptop.
  4. Gently lift keyboard.
    • Gently lift keyboard.
    • Disconnect keyboard from the laptop.
  5. Use a prying tool to remove the upper cover.
    • Use a prying tool to remove the upper cover.
  6. Locate the hard drive.
    • Locate the hard drive.
    • Lift the hard drive.
    • Disconnect hard drive.
  7. Remove the top left screw that is connecting the display assembly and the body of the laptop.
    • Remove the top left screw that is connecting the display assembly and the body of the laptop.
    • Remove the 2.5 mm by 5 mm screw by using #0 Phillips head screw driver.
  8. Using a #0 Phillips screw driver, remove the other 2.5 mm by 5 mm phillips screw that holds the display assembly.
    • Using a #0 Phillips screw driver, remove the other 2.5 mm by 5 mm phillips screw that holds the display assembly.
  9. Gently disconnect the display cable connector between the display assembly and the motherboard.
    • Gently disconnect the display cable connector between the display assembly and the motherboard.
  10. Remove the tape holding  down the display cable that connects it to the motherboard.
    • Remove the tape holding down the display cable that connects it to the motherboard.
  11. Disconnect the tape that is holding the white antenna cable to the motherboard.
    • Disconnect the tape that is holding the white antenna cable to the motherboard.
  12. Take the display assembly off and replace it with a new one.
    • Take the display assembly off and replace it with a new one.
終わりに
Mohd Yuthly
メンバー登録日: 2019年07月08日
133 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S2-G4, Harley Summer 2019 IUPUI, Team S2-G4, Harley Summer 2019人のメンバー
IUPUI-HARLEY-SU19S2G4
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 10
今までの合計 218
