メインコンテンツにスキップ
はじめに
Does the laptop screen not show complete images? Replace it.
パーツ
パーツは指定されていません。
  1. Unlock the battery by pushing the button to the right.
    • Unlock the battery by pushing the button to the right.
  2. Unscrew the eighteen 8 mm Phillips #0 screws attached to the laptop.
    • Unscrew the eighteen 8 mm Phillips #0 screws attached to the laptop.
  3. Pry open the keyboard at the top of the keyboard.
    • Pry open the keyboard at the top of the keyboard.
  4. Disconnect the keyboard label connected to the laptop.
    • Disconnect the keyboard label connected to the laptop.
  5. Carefully pry open the keyboard frame.
    • Carefully pry open the keyboard frame.
  6. Locate the Wi-Fi card.
    • Locate the Wi-Fi card.
  7. Disconnect the two wires connected to the Wi-Fi card.
    • Disconnect the two wires connected to the Wi-Fi card.
  8. Unscrew the two 8mm Philips #0 screws attached to the Wi-Fi card.
    • Unscrew the two 8mm Philips #0 screws attached to the Wi-Fi card.
  9. Carefully remove the CPU fan.
    • Carefully remove the CPU fan.
終わりに
Joe Niu
メンバー登録日: 2017年09月20日
598 ポイント
5のガイドは作成済み
チーム
University of North Texas, Team S5-G1, Thomas Fall 2017 University of North Texas, Team S5-G1, Thomas Fall 2017人のメンバー
UNT-THOMAS-F17S5G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 530
