はじめに
How to replace or upgrade the Hard Drive.
Please SUBSCRIBE to my channel ツ
ビデオの概要
  1. Turn off the laptop and remove the battery. Remove two screws securing the Keyboard. The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Remove the Keyboard and disconnect the two flex cables: Keyboard flex cable Keyboard Light flex cable
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Remove 4x phillips screws and disconnect: Power On button flex cable Touch pad flex cable
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Carefully separate the upper cover and remove it. Carefully separate the upper cover and remove it. Carefully separate the upper cover and remove it.
    • Carefully separate the upper cover and remove it.
  6. Gently remove the HDD and disconnect the SATA cable from it. Please SUBSCRIBE to my channel  ツ Please SUBSCRIBE to my channel  ツ
まとめ
23 の人々がこのガイドを完成させました。
ZFix
メンバー登録日: 2013年12月09日
162,554 ポイント
304のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
280 メンバー
784のガイドは作成済み
Good job! What a pain, though, to swap the HDD :)
Steve Wojciechowski - 返信
I am currently working on this laptop and it doesn't open at all like this one. This is only one back... and 18 screws holding it on. I can partially snap the back off but i can't pry it apart by the dvd drive. I'm also guessing the same model is manufactured differently for different retailers. (This happens in the retail hardware world where a dewalt drill from home depot will be made cheaper than a dewalt from ace hardware) so now I"m stuck. any ideas would be helpful. thanks.
FallenAnjel - 返信
ok found the problem. i accidentally popped out the dvd drive (when I was just trying to open it lol) and up under the lip I found three 1/8" long very-flat head screws. unscrewed those and the back came right off.
FallenAnjel - 返信
New customer that does like shopping local with recommended proprietors and stockiest of the required components.
Thank you Mr Jason Paul Cominelli.
Jason Paul Cominelli - 返信
are 9mm hard disk can fit?
the original was 7mm
jason.chiah1008 - 返信
統計データを表示:
過去 24時間: 25
過去 7 日: 142
過去 30 日: 774
今までの合計 50,860
