はじめに
The hard drive is a storage device with 500 GB that can store data for a long time.
By following this guide you will be able to remove the Acer Aspire V5-473P-5602 hard drive in order to replace it or access other parts.
必要な工具と部品
Flip the laptop over so the back panel is facing upwards.
Use the Phillips #0 screwdriver to remove seventeen 2.5mm screws.
Remove the back panel from the laptop using an iFixit opening tool.
ある他の人がこのガイドを完成しました。
