メインコンテンツにスキップ
Acer Aspire V5-131-2629 Hard Drive Replacement
必要な工具と部品
  1. Acer Aspire V5-131-2629 Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Hard Drive Replacement: 手順 2、 1の画像 1
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Hard Drive Replacement: 手順 3、 1の画像 1
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Hard Drive Replacement: 手順 4、 2の画像 1 Acer Aspire V5-131-2629 Hard Drive Replacement: 手順 4、 2の画像 2
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 Hard Drive Replacement, Cover: 手順 5、 1の画像 1
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 Hard Drive Replacement: 手順 6、 2の画像 1 Acer Aspire V5-131-2629 Hard Drive Replacement: 手順 6、 2の画像 2
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 Hard Drive Replacement, Hard Drive: 手順 7、 1の画像 1
    • Locate the large blue hard drive on the left side on the computer.
  8. Acer Aspire V5-131-2629 Hard Drive Replacement: 手順 8、 1の画像 1
    • Gently pull out the ribbon cable on the computer-attached end.
  9. Acer Aspire V5-131-2629 Hard Drive Replacement: 手順 9、 1の画像 1
    • Completely remove the hard drive from the hard drive bay.
  10. Acer Aspire V5-131-2629 Hard Drive Replacement: 手順 10、 2の画像 1 Acer Aspire V5-131-2629 Hard Drive Replacement: 手順 10、 2の画像 2
    • Remove the two screws on the side of the hard drive cage.
  11. Acer Aspire V5-131-2629 Hard Drive Replacement: 手順 11、 2の画像 1 Acer Aspire V5-131-2629 Hard Drive Replacement: 手順 11、 2の画像 2
    • Pull the hard drive cage from the hard drive to separate the two.
終わりに
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Nicole B Bosse
メンバー登録日: 10/27/19
175 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 UMass Dartmouth, Team S1-G3, O'Connell Fall 2019人のメンバー
UMASSD-O'CONNELL-F19S1G3
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 22
今までの合計 1,615
