はじめに
The touchpad can become unresponsive or just break all together. This guide will show how to safely remove and replace the touchpad in your Acer Aspire laptop.
必要な工具と部品
Remove the nine 4mm screws with a PH0 screwdriver.
Remove the two 6mm screws with a PH0 screwdriver.
Use the spudger to pop up the latch on the ZIF connector.
Pull out the ribbon cable.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
