メインコンテンツにスキップ
Acer Aspire V5-122P-0468 Hard Drive Replacement
必要な工具と部品
  1. Acer Aspire V5-122P-0468 Hard Drive Replacement, Battery: 手順 1、 2の画像 1 Acer Aspire V5-122P-0468 Hard Drive Replacement, Battery: 手順 1、 2の画像 2
    • Remove the nine 4mm screws with a PH0 screwdriver.
    • Remove the two 6mm screws with a PH0 screwdriver.
  2. Acer Aspire V5-122P-0468 Hard Drive Replacement: 手順 2、 2の画像 1 Acer Aspire V5-122P-0468 Hard Drive Replacement: 手順 2、 2の画像 2
    • Remove the black rubber tab on the back of the computer
    • Remove the 4mm screw hidden underneath the black tab with a PH0 screwdriver.
  3. Acer Aspire V5-122P-0468 Hard Drive Replacement: 手順 3、 2の画像 1 Acer Aspire V5-122P-0468 Hard Drive Replacement: 手順 3、 2の画像 2
    • Orient the computer upside down, with the hinges facing away from you.
    • Find the black plastic piece in the SD card slot on the right side of the computer.
    • Remove the plastic piece by sliding it out of the SD card slot.
  4. Acer Aspire V5-122P-0468 Hard Drive Replacement: 手順 4、 3の画像 1 Acer Aspire V5-122P-0468 Hard Drive Replacement: 手順 4、 3の画像 2 Acer Aspire V5-122P-0468 Hard Drive Replacement: 手順 4、 3の画像 3
    • Insert a spudger at these eight locations to disengage the plastic tabs from the housing cover, and pry apart.
    • Continue around the entire perimeter of the cover with the spudger.
    • Use a spudger to pry the cover around I/O ports.
  5. Acer Aspire V5-122P-0468 Hard Drive Replacement: 手順 5、 3の画像 1 Acer Aspire V5-122P-0468 Hard Drive Replacement: 手順 5、 3の画像 2 Acer Aspire V5-122P-0468 Hard Drive Replacement: 手順 5、 3の画像 3
    • Remove the two 4mm screws using a PH0 screwdriver.
    • Depress the tabs holding the battery with a spudger.
    • Disconnect the battery connector from the motherboard using a spudger.
    • Pull the battery up and away from the laptop to remove.
  6. Acer Aspire V5-122P-0468 Hard Drive Replacement, Hard Drive: 手順 6、 3の画像 1 Acer Aspire V5-122P-0468 Hard Drive Replacement, Hard Drive: 手順 6、 3の画像 2 Acer Aspire V5-122P-0468 Hard Drive Replacement, Hard Drive: 手順 6、 3の画像 3
    • Use a plastic opening tool to pop the latch up on the ZIF connector up.
    • Pull out the ribbon cable to disconnect it from one side.
    • The cable can be left connected to the other side.
    • Remove the black isolation pad.
  7. Acer Aspire V5-122P-0468 Hard Drive Replacement: 手順 7、 2の画像 1 Acer Aspire V5-122P-0468 Hard Drive Replacement: 手順 7、 2の画像 2
    • Disconnect the data connector from the motherboard using a plastic opening tool.
  8. Acer Aspire V5-122P-0468 Hard Drive Replacement: 手順 8、 1の画像 1
    • Remove three 4mm Phillips #0 screws.
    • Remove hard drive with rail attached from laptop.
  9. Acer Aspire V5-122P-0468 Hard Drive Replacement: 手順 9、 2の画像 1 Acer Aspire V5-122P-0468 Hard Drive Replacement: 手順 9、 2の画像 2
    • Remove the four 3mm Phillips #0 screws located on the side of the rails.
    • Separate the hard drive from the mounting rail.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Nat McCormick
メンバー登録日: 02/15/18
801 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S16-G1, Boczar Spring 2018 USF Tampa, Team S16-G1, Boczar Spring 2018人のメンバー
USFT-BOCZAR-S18S16G1
5 メンバー
10のガイドは作成済み
コメント 1 件
What would be the correct hard drive upgrade. Something to make this laptop faster mines the 500gb the processor is and dual core prossee a4-1250
Lara Mcneese - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 27
今までの合計 2,348
