はじめに
Removing the back panel gives access to most everything else in the laptop.
必要な工具と部品
Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
ある他の人がこのガイドを完成しました。
コメント 1 件
Is the hard drive accessible for replacement from the bottom? I see black stuff over the drive with the WIFI cables going underneath. Is that removable so one can access the drive from the bottom, or is it accessible from under the keyboard?
danwat1234 - 返信
