必要な工具と部品
Remove the single screw with a Phillips #0 screwdriver.
Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
Remove the eleven screws that hold that back panel to the laptop using a J0 Phillips screwdriver bit.
The battery will be on the side closest to the screen.
Gently lift it out. It will still be attached by white, red, and black wires.
To reassemble your device, follow these instructions in reverse order. When reattaching the back panel, make sure to pry out the pwr on/off slide switch near the center. The back panel switches it off when closing, and there is no other way to avoid it.
3 の人々がこのガイドを完成させました。
コメント 1 件
Great instructions but there is one step missing. There are three more screws holding the key board on. Once you remove the mouse they are under that part. Other than that thanks.
