メインコンテンツにスキップ
Acer Aspire TimelineX 4830T-6682 Battery Replacement
必要な工具と部品
  1. Acer Aspire TimelineX 4830T-6682 Battery Replacement, Lower Back Panel: 手順 1、 3の画像 1 Acer Aspire TimelineX 4830T-6682 Battery Replacement, Lower Back Panel: 手順 1、 3の画像 2 Acer Aspire TimelineX 4830T-6682 Battery Replacement, Lower Back Panel: 手順 1、 3の画像 3
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
  2. Acer Aspire TimelineX 4830T-6682 Battery Replacement, RAM: 手順 2、 3の画像 1 Acer Aspire TimelineX 4830T-6682 Battery Replacement, RAM: 手順 2、 3の画像 2 Acer Aspire TimelineX 4830T-6682 Battery Replacement, RAM: 手順 2、 3の画像 3
    • After the panel has been removed, locate the RAM. It should be on the lower right.
    • There are pins around the RAM that need to be pulled back. After the pins are removed, pull the RAM chip towards you to remove it.
  3. Acer Aspire TimelineX 4830T-6682 Battery Replacement, Keyboard: 手順 3、 1の画像 1
    • Remove the eleven screws that hold that back panel to the laptop using a J0 Phillips screwdriver bit.
  4. Acer Aspire TimelineX 4830T-6682 Battery Replacement: 手順 4、 3の画像 1 Acer Aspire TimelineX 4830T-6682 Battery Replacement: 手順 4、 3の画像 2 Acer Aspire TimelineX 4830T-6682 Battery Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    $3.99
    購入する
    • Place the laptop in the upright position, the lower front touchpad panel should be easily detatched at this point.
    • Remove the lower front touchpad panel by using an angled tweezers to disconnect the only wired tape connected to the motherboard.
  5. Acer Aspire TimelineX 4830T-6682 Battery Replacement: 手順 5、 1の画像 1
    • Next, disconnect the 4 wired tapes of the keyboard from the motherboard just like we did with the lower front touchpad panel.
  6. Acer Aspire TimelineX 4830T-6682 Battery Replacement: 手順 6、 2の画像 1 Acer Aspire TimelineX 4830T-6682 Battery Replacement: 手順 6、 2の画像 2
    • Finally, using an opening tool, gently pry along the edge of the keyboard to separate it from the laptop.
  7. Acer Aspire TimelineX 4830T-6682 Battery Replacement, Battery: 手順 7、 1の画像 1
    • The battery will be on the side closest to the screen.
    • Gently lift it out. It will still be attached by white, red, and black wires.
  8. Acer Aspire TimelineX 4830T-6682 Battery Replacement: 手順 8、 2の画像 1 Acer Aspire TimelineX 4830T-6682 Battery Replacement: 手順 8、 2の画像 2
    • Pull the white plug, it should easily detach.
    • Remove the battery from the device.
終わりに
To reassemble your device, follow these instructions in reverse order. When reattaching the back panel, make sure to pry out the pwr on/off slide switch near the center. The back panel switches it off when closing, and there is no other way to avoid it.
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Rachel Wagner
メンバー登録日: 09/25/17
277 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S3-G6, Thompson Fall 2017 University of North Texas, Team S3-G6, Thompson Fall 2017人のメンバー
UNT-THOMPSON-F17S3G6
4 メンバー
5のガイドは作成済み
コメント 1 件
Great instructions but there is one step missing. There are three more screws holding the key board on. Once you remove the mouse they are under that part. Other than that thanks.
Chris Webber - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 28
今までの合計 5,465
