メインコンテンツにスキップ
Acer Aspire Switch 10 SW5-012-18MY Battery Replacement
必要な工具と部品
  1. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement, Battery: 手順 1、 2の画像 1 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement, Battery: 手順 1、 2の画像 2
    • Remove the tablet from the keyboard.
    • You will not be needing the keyboard for this guide.
  2. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 2、 3の画像 1 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 2、 3の画像 2 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 2、 3の画像 3
    • Use the opening tool to open the back cover. The opening tool should fit under the cover if you place it above the power button.
    • Lift this side of the back cover once the opening tool is inside the device.
    • Use the opening tool and your hands to gradually work around the edges of the cover.
  3. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 3、 2の画像 1 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 3、 2の画像 2
    • Lift the back cover off of the device with your hands.
    • You will need to use some force to pull off the back cover.
  4. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 4、 2の画像 1 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 4、 2の画像 2
    • Remove the piece of black, thin tape that is attached to the circuit board closest to the power button.
  5. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 5、 3の画像 1 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 5、 3の画像 2 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 5、 3の画像 3
    • Use the opening tool to lift the ZIF connector holding the ribbon cable in place on the circuit board.
    • Pull out the ribbon cable from the circuit board. This cable should have the word "Audio" on it.
  6. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 6、 3の画像 1 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 6、 3の画像 2 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 6、 3の画像 3
    • Remove the piece of thin, black tape that is attached to the circuit board on the other side of the battery.
    • Use the opening tool to lift the black ZIF connector holding the ribbon cable in place.
  7. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 7、 2の画像 1 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 7、 2の画像 2
    • Partially remove the piece of black tape that is holding the bundled cable connector to the battery in place.
    • Pull on the battery's bundled cable connector to unplug it from the circuit board.
  8. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 8、 1の画像 1
    • Using the Phillips #000 screwdriver, remove the 3 mm screw that is holding the battery in place.
  9. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 9、 1の画像 1
    • Gently remove the ribbon cable from the battery.
  10. Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 10、 2の画像 1 Acer Aspire Switch 10 SW5-012-18MY Battery Replacement: 手順 10、 2の画像 2
    • Carefully remove the battery from the device by lifting it up.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Grecia Corrada
メンバー登録日: 03/19/18
1,134 ポイント
6のガイドは作成済み
チーム
Baylor, Team S3-G3, Williams Spring 2018 Baylor, Team S3-G3, Williams Spring 2018人のメンバー
BU-WILLIAMS-S18S3G3
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 45
今までの合計 4,421
