はじめに
The screen is a very important part of the laptop, as it allows users to access the internet and a variety of other resources. If your laptop screen is cracked or displays no image, then it may be damaged and will need to be replaced. The goal of this guide is to show how to replace a broken or damaged laptop screen. It is a relatively straightforward process, and does not even require you to open the bottom half of the device. In this guide, a plastic opening tool, a spudger, and a Phillips #0 screwdriver will be needed. The steps required for this guide will only take a few minutes to complete.
  1. Use the plastic opening tool around the edges of the screen and remove the outer screen casing (the bezel).
    • Use the plastic opening tool around the edges of the screen and remove the outer screen casing (the bezel).
  2. Locate the black strip at the bottom of the screen, just above the power button.
    • Locate the black strip at the bottom of the screen, just above the power button.
    • Use the spudger to disconnect this wire from the screen.
    • Disconnect the wire leading around the screen with a spudger or a plastic opening tool.
    • Locate the six 3 mm screws (there are three on each side of the screen). Remove them with the Phillips #0 screwdriver.
    • Pull the screen (the entire top half) backwards off the hinges of the laptop.
まとめ
Cynthia Bennett
メンバー登録日: 2018年10月17日
553 ポイント
5のガイドは作成済み
チーム
UW Tacoma, Team S1-G1, Rose Fall 2018 UW Tacoma, Team S1-G1, Rose Fall 2018人のメンバー
UWT-ROSE-F18S1G1
4 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 35
今までの合計 48
