はじめに
This guide will walk you through removing the speakers. The speakers may need to be removed if they are damaged, or just to access the components beneath them.
  1. Remove the 12 5mm Phillips #00 screws. Use a plastic opening tool to gently pry open the back panel. Gently lift up the back panel, exposing the internals of the laptop.
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  3. Unscrew the 4 1mm PH00 screws attaching the speakers to the frame. Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
    • Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
  4. Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
    • Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
まとめ
Nikolas I Steckley
メンバー登録日: 2018年09月17日
521 ポイント
5のガイドは作成済み
チーム
Washington State, Team S1-G4, Hope Fall 2018 Washington State, Team S1-G4, Hope Fall 2018人のメンバー
WSU-HOPE-F18S1G4
3 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 7
今までの合計 40
