はじめに
This guide will walk you through removing the keyboard. The keyboard may need to be removed if it is damaged, or simply for easy access to clean.
必要な工具と部品
Remove the 12 5mm Phillips #00 screws.
Use a plastic opening tool to gently pry open the back panel.
Gently lift up the back panel, exposing the internals of the laptop.
Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
The 30 1mm PH000 screws holding the keyboard in place will be distributed all over the back.
You will need to gently pry up the black tape to expose the remaining screws.
ある他の人がこのガイドを完成しました。
