はじめに
This guide will walk you through disconnecting the display assembly. You may need to remove the display assembly if it is damaged and needs repair, or simply for cleaning.
パーツ
パーツは指定されていません。
Remove the 12 5mm Phillips #00 screws.
Use a plastic opening tool to gently pry open the back panel.
Gently lift up the back panel, exposing the internals of the laptop.
Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
Unscrew the 10 5mm PH00 screws from the hinges attaching the display assembly to the base.
2 の人々がこのガイドを完成させました。
2 件のコメント
Hey where can I find the screen for this model, cause currently my laptop screen backlight spoiled.
Harry joel - 返信
You can find this screen on 3rd party sites such as newegg and ebay.
