メインコンテンツにスキップ
はじめに
RAM, or random-access memory, is an important component to keep your computer running smoothly. Occasionally, RAM can wear out or become unseated, and need to be replaced.
パーツ
パーツは指定されていません。
  1. Turn off the laptop and disconnect the power adapter before attempting this guide. Failure to do so can result in a shock hazard.
    • Turn off the laptop and disconnect the power adapter before attempting this guide. Failure to do so can result in a shock hazard.
  2. Remove the top and middle grips that conceal 3 additional screws. Remove the (8) 10mm T9 screws. Remove the (5) 6mm T9 screws.
    • Remove the top and middle grips that conceal 3 additional screws.
    • Remove the (8) 10mm T9 screws.
    • Remove the (5) 6mm T9 screws.
  3. Remove back panel.
    • Remove back panel.
  4. Press in on the release levers on either side of the stick of RAM. Carefully lift and remove the RAM.
    • Press in on the release levers on either side of the stick of RAM.
    • Carefully lift and remove the RAM.
終わりに
ある他の人がこのガイドを完成しました。
Evan Casey
メンバー登録日: 2018年09月10日
300 ポイント
2のガイドは作成済み
チーム
Appalachian State University, Team S2-G5, Menagarishvili Fall 2018 Appalachian State University, Team S2-G5, Menagarishvili Fall 2018人のメンバー
APSU-MENAGARISHVILI-F18S2G5
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 256
