メインコンテンツにスキップ
Acer Aspire R5-571T-59DC Motherboard Replacement
必要な工具と部品
  1. Acer Aspire R5-571T-59DC  Motherboard Replacement, Back Cover Panel: 手順 1、 2の画像 1 Acer Aspire R5-571T-59DC  Motherboard Replacement, Back Cover Panel: 手順 1、 2の画像 2
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC  Motherboard Replacement, Battery: 手順 2、 3の画像 1 Acer Aspire R5-571T-59DC  Motherboard Replacement, Battery: 手順 2、 3の画像 2 Acer Aspire R5-571T-59DC  Motherboard Replacement, Battery: 手順 2、 3の画像 3
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
  3. Acer Aspire R5-571T-59DC  Motherboard Replacement, Hard Drive: 手順 3、 1の画像 1
    • Use a spudger to flip up the retaining flap on the hard drive ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  4. Acer Aspire R5-571T-59DC  Motherboard Replacement: 手順 4、 1の画像 1
    • Lift the hard drive up and out of the laptop.
  5. Acer Aspire R5-571T-59DC  Motherboard Replacement, Fan: 手順 5、 1の画像 1
    • Remove the seven 0.7mm Phillips #00 screws securing the fan in place.
  6. Acer Aspire R5-571T-59DC  Motherboard Replacement: 手順 6、 1の画像 1
    • Unplug fan from motherboard.
    • Lift and remove fan from case.
  7. Acer Aspire R5-571T-59DC  Motherboard Replacement, RAM: 手順 7、 1の画像 1
    • Lift up the protective covering away from the RAM using tweezers, or your fingers.
  8. Acer Aspire R5-571T-59DC  Motherboard Replacement: 手順 8、 3の画像 1 Acer Aspire R5-571T-59DC  Motherboard Replacement: 手順 8、 3の画像 2 Acer Aspire R5-571T-59DC  Motherboard Replacement: 手順 8、 3の画像 3
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    • When released, the RAM module will pop up at a slight angle.
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
  9. Acer Aspire R5-571T-59DC  Motherboard Replacement, Motherboard: 手順 9、 1の画像 1
    • Remove the nine 0.7mm Phillips #00 screws from the motherboard.
  10. Acer Aspire R5-571T-59DC  Motherboard Replacement: 手順 10、 1の画像 1
    • Use a spudger to flip up the retaining flaps on all of the ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
    • Lift up and remove the motherboard.
終わりに
作成者
3人の作成者と共同で作成されました。
Kelly Johnston
メンバー登録日: 01/25/18
600 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team S20-G2, Passmore Spring 2018 USF Tampa, Team S20-G2, Passmore Spring 2018人のメンバー
USFT-PASSMORE-S18S20G2
3 メンバー
7のガイドは作成済み
コメント 1 件
Hi, my laptop is Acer R5-571TG-765T.
1. Does the bare bones motherboard have the same physical configuration as your R5-571T-59DC?
2. Is M.2 NVMe SSD compatible with my motherboard?
3. My laptop runs hot even with a cooling fan stand beneath. Would you recommend NVMe?
4. If heat is a problem, and availability of reputable and affordable M.2 SATA is lacking where I am -- will I be able to use a 2.5" SATA SSD as a boot drive and keep my existing 2.5" SATA HDD as a D drive at the same time?
Thank you!
availability - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 9
今までの合計 1,905
