メインコンテンツにスキップ
Acer Aspire R5-471T-52EE Screen Replacement
必要な工具と部品
  1. Acer Aspire R5-471T-52EE Screen Replacement, Back Cover: 手順 1、 2の画像 1 Acer Aspire R5-471T-52EE Screen Replacement, Back Cover: 手順 1、 2の画像 2
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Screen Replacement: 手順 2、 1の画像 1
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Screen Replacement, Screen: 手順 3、 1の画像 1
    • Disconnect the three wires from the motherboard that connect to the screen.
    • Be very gentle when removing these wires as the connections with the motherboard are delicate.
  4. Acer Aspire R5-471T-52EE Screen Replacement: 手順 4、 1の画像 1
    • Remove the eight 3mm screws on the hinges using the Phillips #1 screwdriver.
    • Now that the hinges have been unfastened, carefully separate the screen and screen casing from the other half of the computer.
  5. Acer Aspire R5-471T-52EE Screen Replacement: 手順 5、 2の画像 1 Acer Aspire R5-471T-52EE Screen Replacement: 手順 5、 2の画像 2
    • Using a spudger or an opening pick, pop open the case holding the screen. Follow the line where the two pieces of the case meet all around the screen.
    • Remove the display assembly from the device.
終わりに
To install the screen and reassemble your device, follow these instructions in reverse order.
作成者
2人の作成者と共同で作成されました。
Arda Cetken
メンバー登録日: 01/16/20
639 ポイント
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 12
今までの合計 358
