はじめに
This guide will give you step-by-step instructions on how to safely and successfully remove the RAM from your Acer Aspire R11 R3-131T-C1Z5.
必要な工具と部品
Flip the laptop on to its front, so that the back is facing up
Unscrew the twelve 19.05 mm PH#0 screws.
Connect the clip of an anti-static wrist strap to any piece of metal on the computer.
2 の人々がこのガイドを完成させました。
4 件のコメント
can u remove ram without removing battery ?
no, you can’t if you don’t remove the battery you will probably get shocked if you don’t remove the battery I highly recommend removing the battery
Thanks to this site; always a life saver
I replace my 2GB of RAM to 4GB of RAM it’s much faster but the computer does not have an HD or SSD and my is a different model
