はじめに
After removing the top case, it is easy to get to the internal wireless card.
必要な工具と部品
Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
Gently lift up the left side of the wireless card and slide the card out of its socket.
Close the display and turn the ZG5 over so that the battery compartment faces away from you.
Disconnect the two antenna cables from the right side of the wireless card.
5 の人々がこのガイドを完成させました。
