メインコンテンツにスキップ
Acer Aspire One D270-1865 Screen Replacement
必要な工具と部品
  1. Acer Aspire One D270-1865 Screen Replacement, LCD Screen: 手順 1、 3の画像 1 Acer Aspire One D270-1865 Screen Replacement, LCD Screen: 手順 1、 3の画像 2 Acer Aspire One D270-1865 Screen Replacement, LCD Screen: 手順 1、 3の画像 3
    • Put on an anti-static wrist band, attaching the end onto a large piece of metal.
    • Make sure the laptop is unplugged from its charging cord.
    • Flip the laptop over to view the underside.
    • Slide the right battery lock/unlock button to unlock, sliding the tab outward to unlock.
    • At the same time, slide the left tab outwards while placing a thumb on the grip strips of the battery and pull the battery outwards until it slides out.
  2. Acer Aspire One D270-1865 Screen Replacement: 手順 2、 3の画像 1 Acer Aspire One D270-1865 Screen Replacement: 手順 2、 3の画像 2 Acer Aspire One D270-1865 Screen Replacement: 手順 2、 3の画像 3
    • Using a Phillips #00 screwdriver, unscrew the three 2mm screws on the bottom of the laptop,
    • Flip the laptop over right-side up and open the laptop.
  3. Acer Aspire One D270-1865 Screen Replacement: 手順 3、 3の画像 1 Acer Aspire One D270-1865 Screen Replacement: 手順 3、 3の画像 2 Acer Aspire One D270-1865 Screen Replacement: 手順 3、 3の画像 3
    • Carefully insert the blue plastic opening tool between the F8 key and the blue plastic covering.
    • Try not to damage the F8 key.
    • After insertion, carefully slide the tool popping the keyboard out.
    • The keyboard is still attached to the blue casing by a ribbon cable.
    • On the bottom of the keyboard, gently pull the ribbon cable out of the cable holder.
  4. Acer Aspire One D270-1865 Screen Replacement: 手順 4、 3の画像 1 Acer Aspire One D270-1865 Screen Replacement: 手順 4、 3の画像 2 Acer Aspire One D270-1865 Screen Replacement: 手順 4、 3の画像 3
    • Using a Phillips #00 screwdriver, remove each screw:
    • Eleven 2mm Phillips #00 screws
    • Three 2mm Phillips #00 screws
    • Using the opening tool, gently insert it into the crack of the blue casing and the bottom of the laptop.
    • Begin separating the two until the blue casing is fully off.
  5. Acer Aspire One D270-1865 Screen Replacement: 手順 5、 3の画像 1 Acer Aspire One D270-1865 Screen Replacement: 手順 5、 3の画像 2 Acer Aspire One D270-1865 Screen Replacement: 手順 5、 3の画像 3
    • Using a Phillips #00 screwdriver, remove the screws on the hinges holding the laptop screen and the keyboard together:
    • One 2mm Phillips #00 screws
    • On the left hinge, gently lift up the motherboard and carefully pull out the hinge.
  6. Acer Aspire One D270-1865 Screen Replacement: 手順 6、 3の画像 1 Acer Aspire One D270-1865 Screen Replacement: 手順 6、 3の画像 2 Acer Aspire One D270-1865 Screen Replacement: 手順 6、 3の画像 3
    • Using a #1.0 flat head screwdriver, remove the two black circle covers on bottom corners of the screen.
    • Place the covers facing up since the bottom of the covers are sticky.
    • Remove the two 2mm Phillips #00 screws holding the screen casing to the screen.
  7. Acer Aspire One D270-1865 Screen Replacement: 手順 7、 2の画像 1 Acer Aspire One D270-1865 Screen Replacement: 手順 7、 2の画像 2
    • Insert the opening tool between the screen casing and the back casing.
    • Begin separation until the casing and the back is fully separated.
  8. Acer Aspire One D270-1865 Screen Replacement: 手順 8、 3の画像 1 Acer Aspire One D270-1865 Screen Replacement: 手順 8、 3の画像 2 Acer Aspire One D270-1865 Screen Replacement: 手順 8、 3の画像 3
    • Remove the four 2mm Phillips #00 screws holding the screen in place.
    • Gently lift the screen up while holding down the cable cord at the top of the screen.
    • Gently remove the cable cord from its outlet.
  9. Acer Aspire One D270-1865 Screen Replacement: 手順 9、 3の画像 1 Acer Aspire One D270-1865 Screen Replacement: 手順 9、 3の画像 2 Acer Aspire One D270-1865 Screen Replacement: 手順 9、 3の画像 3
    • Remove the yellow sticky tape at the bottom of the screen.
    • Gently pull the cable at the bottom of the screen, detaching all wires and the tape from screen.
    • Remove the screen.
終わりに
6 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Mai
メンバー登録日: 04/01/16
370 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team 2-4, Andersen Spring 2016 Eastern Washington University, Team 2-4, Andersen Spring 2016人のメンバー
EWU-ANDERSEN-S16S2G4
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 3,628
