メインコンテンツにスキップ
Acer Aspire One D255E RAM Replacement
必要な工具と部品
  1. Acer Aspire One D255E RAM Replacement, Keyboard: 手順 1、 1の画像 1
    • Start by removing the battery found on the back of the device.
    • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
  2. Acer Aspire One D255E RAM Replacement: 手順 2、 2の画像 1 Acer Aspire One D255E RAM Replacement: 手順 2、 2の画像 2
    • Using plastic opening tools press down the 6 clips located around the keyboard.
  3. Acer Aspire One D255E RAM Replacement: 手順 3、 3の画像 1 Acer Aspire One D255E RAM Replacement: 手順 3、 3の画像 2 Acer Aspire One D255E RAM Replacement: 手順 3、 3の画像 3
    • Using a plastic opening tool or spudger move the keyboard out of position.
    • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
    • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E RAM Replacement: 手順 4、 1の画像 1
    • Using a spudger gently push the tab on the port forward then pull out the cable.
    • Be careful to do so as gently as possible. You do not want to damage the port.
  5. Acer Aspire One D255E RAM Replacement, Back Panel: 手順 5、 2の画像 1 Acer Aspire One D255E RAM Replacement, Back Panel: 手順 5、 2の画像 2
    • Unscrew seven 1.2 mm Phillips #1 screws from the back of the device
  6. Acer Aspire One D255E RAM Replacement: 手順 6、 2の画像 1 Acer Aspire One D255E RAM Replacement: 手順 6、 2の画像 2
    • Unscrew eight more 1.2 mm Phillips #1 screws from the front of the computer.
  7. Acer Aspire One D255E RAM Replacement: 手順 7、 3の画像 1 Acer Aspire One D255E RAM Replacement: 手順 7、 3の画像 2 Acer Aspire One D255E RAM Replacement: 手順 7、 3の画像 3
    • Using a spudger carefully push though the hole to dislodge the panel on the back of the device then remove the panel by hand.
    • It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  8. Acer Aspire One D255E RAM Replacement, RAM: 手順 8、 3の画像 1 Acer Aspire One D255E RAM Replacement, RAM: 手順 8、 3の画像 2 Acer Aspire One D255E RAM Replacement, RAM: 手順 8、 3の画像 3
    • Using your hands pull apart the two clips holding the RAM in then pull out the RAM.
    • It uses (DDR3) 204pin PC3-10600 1333MHz DDR3 SO-DIMM Memory Modules
終わりに
7 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Brian
メンバー登録日: 03/19/16
1,302 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 UMass Dartmouth, Team 16-8, Bhusal Spring 2016人のメンバー
UMASSD-BHUSAL-S16S16G8
2 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 23
過去 30 日: 36
今までの合計 4,742
