はじめに
The hard drive is one of the more crucial components on a computer. There are a variety of different reasons one would want to replace a hard drive including upgrading the size and replacing a malfunctioning component. You should read through the entire guide before performing the repair and should have all necessary tools readily available. You should also find a safe location to store the various screws taken out of the computer to ensure that they do not get mixed up or lost.
必要な工具と部品
Using a spudger gently push the tab on the port forward then pull out the cable.
please don’t disconnect the keyboard for this job and even for HDD replacement..
it’s useless and you will complicate the life to yourself.
leartzajmi - 返信
Unscrew seven 1.2 mm Phillips #1 screws from the back of the device
This step is not necessary. The screws do not have to be removed for RAM replacement.
Unscrew eight more 1.2 mm Phillips #1 screws from the front of the computer.
Here too many screws are removed. Only the 4 denoted with a circled "1" have to be removed.
just remove the 4 screws that are marked as “Door” or something similar since i don’t remember .. not all those need to be removed
leartzajmi - 返信
13 の人々がこのガイドを完成させました。
4 件のコメント
It is not at all necessary to remove all those screws! Only the 4 marked DOOR under the keyboard are required to pop off the back cover and access the HDD.
Thank you very much, i thought, must to unscrew all the screws like to disassembly all the mini. I THINK is not nessesary neither, the keyboard
Gabo -
Bonjour il n est pas nécessaire d ôter le clavier pour atteindre le disque dur et la carte mémoire par contre il y a un tout petit boulon à ôter en plus de la vis pour enlever le disque dur
