メインコンテンツにスキップ
Acer Aspire One D255E Hard Drive Replacement
必要な工具と部品
  1. Acer Aspire One D255E Hard Drive Replacement, Keyboard: 手順 1、 1の画像 1
    • Start by removing the battery found on the back of the device.
    • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
  2. Acer Aspire One D255E Hard Drive Replacement: 手順 2、 2の画像 1 Acer Aspire One D255E Hard Drive Replacement: 手順 2、 2の画像 2
    • Using plastic opening tools press down the 6 clips located around the keyboard.
  3. Acer Aspire One D255E Hard Drive Replacement: 手順 3、 3の画像 1 Acer Aspire One D255E Hard Drive Replacement: 手順 3、 3の画像 2 Acer Aspire One D255E Hard Drive Replacement: 手順 3、 3の画像 3
    • Using a plastic opening tool or spudger move the keyboard out of position.
    • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
    • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E Hard Drive Replacement: 手順 4、 1の画像 1
    • Using a spudger gently push the tab on the port forward then pull out the cable.
    • Be careful to do so as gently as possible. You do not want to damage the port.
  5. Acer Aspire One D255E Hard Drive Replacement, Back Panel: 手順 5、 2の画像 1 Acer Aspire One D255E Hard Drive Replacement, Back Panel: 手順 5、 2の画像 2
    • Unscrew seven 1.2 mm Phillips #1 screws from the back of the device
  6. Acer Aspire One D255E Hard Drive Replacement: 手順 6、 2の画像 1 Acer Aspire One D255E Hard Drive Replacement: 手順 6、 2の画像 2
    • Unscrew eight more 1.2 mm Phillips #1 screws from the front of the computer.
  7. Acer Aspire One D255E Hard Drive Replacement: 手順 7、 3の画像 1 Acer Aspire One D255E Hard Drive Replacement: 手順 7、 3の画像 2 Acer Aspire One D255E Hard Drive Replacement: 手順 7、 3の画像 3
    • Using a spudger carefully push though the hole to dislodge the panel on the back of the device then remove the panel by hand.
    • It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  8. Acer Aspire One D255E Hard Drive Replacement, Hard Drive: 手順 8、 2の画像 1 Acer Aspire One D255E Hard Drive Replacement, Hard Drive: 手順 8、 2の画像 2
    • Remove the single 1.2 mm Phillips #1 screw from the Hard Drive.
  9. Acer Aspire One D255E Hard Drive Replacement: 手順 9、 2の画像 1 Acer Aspire One D255E Hard Drive Replacement: 手順 9、 2の画像 2
    • Using the tab on the side of the Hard Drive, pull out the Hard Drive.
終わりに
13 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Brian
メンバー登録日: 03/19/16
1,248 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 UMass Dartmouth, Team 16-8, Bhusal Spring 2016人のメンバー
UMASSD-BHUSAL-S16S16G8
2 メンバー
10のガイドは作成済み
4 件のコメント
It is not at all necessary to remove all those screws! Only the 4 marked DOOR under the keyboard are required to pop off the back cover and access the HDD.
Colin - 返信
Thank you very much, i thought, must to unscrew all the screws like to disassembly all the mini. I THINK is not nessesary neither, the keyboard
Gabo -
The keyboard ribbon was a pain but it worked out in the end.
Terry - 返信
Bonjour il n est pas nécessaire d ôter le clavier pour atteindre le disque dur et la carte mémoire par contre il y a un tout petit boulon à ôter en plus de la vis pour enlever le disque dur
frecer patricia - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 12
過去 30 日: 71
今までの合計 10,653
