メインコンテンツにスキップ
Acer Aspire One D255-1625 RAM Replacement
必要な工具と部品
  1. Acer Aspire One D255-1625 RAM Replacement, Battery: 手順 1、 3の画像 1 Acer Aspire One D255-1625 RAM Replacement, Battery: 手順 1、 3の画像 2 Acer Aspire One D255-1625 RAM Replacement, Battery: 手順 1、 3の画像 3
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D255-1625 RAM Replacement: 手順 2、 1の画像 1
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
  3. Acer Aspire One D255-1625 RAM Replacement, RAM: 手順 3、 1の画像 1
    • Use iFixit’s Jimmy tool to remove the bottom panel of the device.
    • Wedge the tool into the top middle of the panel until the back gently pops off.
  4. Acer Aspire One D255-1625 RAM Replacement: 手順 4、 3の画像 1 Acer Aspire One D255-1625 RAM Replacement: 手順 4、 3の画像 2 Acer Aspire One D255-1625 RAM Replacement: 手順 4、 3の画像 3
    • Push the silver locking tabs on either side of the RAM card outward and the card will pop up to rest at an angle.
    • Slide the card straight out of its housing.
終わりに
作成者
4人の作成者と共同で作成されました。
Alexander Ilibasic
メンバー登録日: 01/30/20
430 ポイント
3のガイドは作成済み
2 件のコメント
I was lazy to do it the proper way and thought this was a short cut... Sadly the author is an a*** and doesn't show that there are two screws connected to the bottom plastic base. Well I ripped them right off. The right way is to remove the key board and then unscrew the two screws after that you can pop the bottom panel.
YuraD95 - 返信
Sorry I was wrong it's not 2 screws it was 5 screws that I ripped off.
YuraD95 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 309
