メインコンテンツにスキップ
Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement
必要な工具と部品
  1. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Remove eleven 4 mm Phillips #1 screws.
    • Pull the backplate off using your fingers.
  2. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 手順 2、 2の画像 1 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 手順 2、 2の画像 2
    • Pull the rainbow cord out of the motherboard using the tabs on the sides.
  3. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 手順 3、 2の画像 1 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 手順 3、 2の画像 2
    • Remove three 3 mm Phillips #1 screws holding down the battery.
    • Lift the top edge of the battery and pull back towards the hinges to remove the battery.
  4. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Motherboard: 手順 4、 2の画像 1 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement, Motherboard: 手順 4、 2の画像 2
    • Remove two 4 mm screws holding down the metal plate using a Phillips #1 screwdriver.
    • Remove the plate using your fingers.
    • Remove four 5 mm screws holding the motherboard in place using a Phillips #1 screwdriver.
  5. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 手順 5、 1の画像 1
    • Pull the yellow cord out from the motherboard using the sticker.
  6. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 手順 6、 2の画像 1 Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 手順 6、 2の画像 2
    • Pull both small blue ribbon cords out of the motherboard using the stickers.
  7. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 手順 7、 1の画像 1
    • Gently pull the black cord out from the motherboard.
  8. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 手順 8、 1の画像 1
    • Pull the top cord out of the motherboard using the sticker.
  9. Acer Aspire One Cloudbook AO1-132-C3T3 Motherboard Replacement: 手順 9、 1の画像 1
    • Gently pull the motherboard away from the small square chip to its left.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Hanna Flores
メンバー登録日: 09/20/17
149 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S6-G3, Thomas Fall 2017 University of North Texas, Team S6-G3, Thomas Fall 2017人のメンバー
UNT-THOMAS-F17S6G3
3 メンバー
4のガイドは作成済み
1 Guide Comment
Hello, can you please advise on how to replace the ram on this laptop
BenfromEssex - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 26
今までの合計 1,210
