メインコンテンツにスキップ
Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement
必要な工具と部品
  1. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement, Back Panel: 手順 1、 3の画像 1 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement, Back Panel: 手順 1、 3の画像 2 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement, Back Panel: 手順 1、 3の画像 3
    • Power the laptop off.
    • Flip the laptop over and position it so the opening faces you.
    • Remove the rubber foot located near the opening side of the device using tweezers.
  2. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 手順 2、 2の画像 1 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 手順 2、 2の画像 2
    • Unscrew the five 5-mm screws using the PH0 screwdriver.
  3. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 手順 3、 3の画像 1 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 手順 3、 3の画像 2 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 手順 3、 3の画像 3
    • Identify the HDMI port located in the side of the laptop opposite to the power button.
    • Insert the plastic opening tool into the divet of the back panel located above the HDMI port.
    • Pry along the laptop frame until the back panel comes loose.
    • Do not pull the back panel too hard as the battery is still connected to the back panel and the motherboard. This can damage your device.
  4. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 手順 4、 2の画像 1 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 手順 4、 2の画像 2
    • Rotate the device so the opening faces you again.
    • Hold the back panel away from the laptop and remove the 4-mm screw using the PH0 screwdriver.
    • This screw is fastening the battery to the laptop.
    • Lift the back panel gently.
  5. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 手順 5、 2の画像 1 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 手順 5、 2の画像 2
    • Unplug the cable that connects the battery to the motherboard.
    • Detach the back panel, which still includes the battery.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
John Hasenbein
メンバー登録日: 09/11/17
119 ポイント
1ガイドが承認済み
チーム
CSU Fullerton, Team S1-G4, Bruce Fall 2017 CSU Fullerton, Team S1-G4, Bruce Fall 2017人のメンバー
CSUF-BRUCE-F17S1G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 957
