メインコンテンツにスキップ
Acer Aspire One AO756-2623 LCD Sceen Replacement
必要な工具と部品
  1. Acer Aspire One AO756-2623 LCD Sceen Replacement, Battery: 手順 1、 1の画像 1
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Acer Aspire One AO756-2623 LCD Sceen Replacement: 手順 2、 1の画像 1
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Acer Aspire One AO756-2623 LCD Sceen Replacement: 手順 3、 3の画像 1 Acer Aspire One AO756-2623 LCD Sceen Replacement: 手順 3、 3の画像 2 Acer Aspire One AO756-2623 LCD Sceen Replacement: 手順 3、 3の画像 3
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Acer Aspire One AO756-2623 LCD Sceen Replacement, LCD Sceen: 手順 4、 1の画像 1
    • Orient the laptop as shown in the picture with the open screen facing toward you.
  5. Acer Aspire One AO756-2623 LCD Sceen Replacement: 手順 5、 3の画像 1 Acer Aspire One AO756-2623 LCD Sceen Replacement: 手順 5、 3の画像 2 Acer Aspire One AO756-2623 LCD Sceen Replacement: 手順 5、 3の画像 3
    • Insert the spudger into the indicated crease.
    • Firmly slide spudger around the edge of the entire laptop to remove the front plate of the screen.
    • Loud cracking noises from the plastic tabs separating may occur, do not worry, they are to be expected.
  6. Acer Aspire One AO756-2623 LCD Sceen Replacement: 手順 6、 3の画像 1 Acer Aspire One AO756-2623 LCD Sceen Replacement: 手順 6、 3の画像 2 Acer Aspire One AO756-2623 LCD Sceen Replacement: 手順 6、 3の画像 3
    • Identify the four 6 mm Phillips screws that are necessary to remove the LCD screen.
    • Remove all four screws using a Phillips #0 Screwdriver.
    • Pull away the LCD screen from the back cover of the laptop without ripping the ribbon cable connecting it to the bottom of the laptop.
  7. Acer Aspire One AO756-2623 LCD Sceen Replacement: 手順 7、 3の画像 1 Acer Aspire One AO756-2623 LCD Sceen Replacement: 手順 7、 3の画像 2 Acer Aspire One AO756-2623 LCD Sceen Replacement: 手順 7、 3の画像 3
    • Remove the tape covering the port connecting the screen to the bottom of the laptop.
    • To remove the LCD screen, gently pull the cable straight out of the screen.
    • In the first and second photos, the screen is lying face down on the keyboard.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Davis Adams
メンバー登録日: 03/20/16
465 ポイント
3のガイドは作成済み
チーム
Clemson, Team 7-1, Benson Spring 2016 Clemson, Team 7-1, Benson Spring 2016人のメンバー
CLEM-BENSON-S16S7G1
4 メンバー
14のガイドは作成済み
コメント 1 件
Spot on! Perfect tutorial thank-you very much!
Sonia Green - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 16
今までの合計 1,020
