メインコンテンツにスキップ
Acer Aspire One AO756-2623 Keyboard Replacement
必要な工具と部品
  1. Acer Aspire One AO756-2623 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Acer Aspire One AO756-2623 Keyboard Replacement: 手順 2、 1の画像 1
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Acer Aspire One AO756-2623 Keyboard Replacement: 手順 3、 3の画像 1 Acer Aspire One AO756-2623 Keyboard Replacement: 手順 3、 3の画像 2 Acer Aspire One AO756-2623 Keyboard Replacement: 手順 3、 3の画像 3
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Acer Aspire One AO756-2623 Keyboard Replacement, Back Cover: 手順 4、 1の画像 1
    • Locate the single 6 mm Phillips screw in the lower middle of the back plate.
    • Remove the screw using a Phillips #0 Screwdriver.
  5. Acer Aspire One AO756-2623 Keyboard Replacement: 手順 5、 2の画像 1 Acer Aspire One AO756-2623 Keyboard Replacement: 手順 5、 2の画像 2
    • Slide the back plate downward to remove it from the laptop.
  6. Acer Aspire One AO756-2623 Keyboard Replacement, Keyboard: 手順 6、 1の画像 1
    • Locate the eighteen 6 mm Phillips screws that are required to remove the keyboard.
    • Remove all screws using a Phillips #0 screwdriver.
  7. Acer Aspire One AO756-2623 Keyboard Replacement: 手順 7、 1の画像 1
    • Orient the laptop to where the open screen is facing towards you.
    • Slide the spuldger into the indicated crease.
    • Firmly slide spudger all the way around the laptop to pry the keyboard away from the bottom of the laptop.
    • Loud cracking noises will be heard during this step.
  8. Acer Aspire One AO756-2623 Keyboard Replacement: 手順 8、 3の画像 1 Acer Aspire One AO756-2623 Keyboard Replacement: 手順 8、 3の画像 2 Acer Aspire One AO756-2623 Keyboard Replacement: 手順 8、 3の画像 3
    • Remove the green dotted ribbon cable by sliding it straight out of the clamp holding it in using a plastic spudger.
    • Locate the two tabs that are holding the larger black ribbon cable in place.
    • Remove the larger black ribbon cable by pressing in the tabs and sliding it straight out of the clamp holding it in using a plastic spudger.
    • To remove the keyboard, lift the keyboard straight away from the rest of the laptop.
  9. Acer Aspire One AO756-2623 Keyboard Replacement: 手順 9、 3の画像 1 Acer Aspire One AO756-2623 Keyboard Replacement: 手順 9、 3の画像 2 Acer Aspire One AO756-2623 Keyboard Replacement: 手順 9、 3の画像 3
    • Locate the ten 6 mm Phillips screws that connect the keyboard to the rest of the laptop and remove them with a Phillips #0 Screwdriver.
    • Locate the four 6 mm Phillips screws hidden beneath black tape by lifting up the black tape and remove them with a Phillips #0 Screwdriver.
    • To remove keyboard from the rest of the laptop, pull keyboard straight up.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Davis Adams
メンバー登録日: 03/20/16
465 ポイント
3のガイドは作成済み
チーム
Clemson, Team 7-1, Benson Spring 2016 Clemson, Team 7-1, Benson Spring 2016人のメンバー
CLEM-BENSON-S16S7G1
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 20
今までの合計 1,494
