メインコンテンツにスキップ
Acer Aspire One A150-1672 Individual Key Replacement
必要な工具と部品
  1. Acer Aspire One A150-1672 Individual Key Replacement, Individual Key: 手順 1、 2の画像 1 Acer Aspire One A150-1672 Individual Key Replacement, Individual Key: 手順 1、 2の画像 2
    • To remove the keyboard, place the Blue Plastic Opening Tool at the 3 indentations above the keyboard as shown.
    • Slip the Blue Plastic Opening Tool in the space between the keyboard and the pink plastic casing and push down.
    • Pushing down on all 3 indentations should cause the keyboard to pop upwards slightly.
  2. Acer Aspire One A150-1672 Individual Key Replacement: 手順 2、 2の画像 1 Acer Aspire One A150-1672 Individual Key Replacement: 手順 2、 2の画像 2
    • There is a notch on the right side of the casing that blocks the keyboards ability to be removed.
    • Use the Blue Plastic opening tool and your fingers to pull up the top part of the keyboard as shown.
    • Use the Blue Plastic Opening Tool to separate the right side of the casing from the keyboard as shown.
    • After you have successfully moved the keyboard out from under the notch, pull the keyboard up.
  3. Acer Aspire One A150-1672 Individual Key Replacement: 手順 3、 1の画像 1
    • Using the Blue Plastic Opening Tool, pull up on the keyboard connector to completely detach the keyboard from the base of the laptop.
  4. Acer Aspire One A150-1672 Individual Key Replacement: 手順 4、 2の画像 1 Acer Aspire One A150-1672 Individual Key Replacement: 手順 4、 2の画像 2
    • Using the Blue Plastic Opening Tool, remove the white plastic piece of your desired key.
    • Place the Blue Plastic Opening Tool on the right side of the individual key, then gently pull up to detach the clips underneath.
    • Remove the key from the hinges by sliding the key to the left.
  5. Acer Aspire One A150-1672 Individual Key Replacement: 手順 5、 2の画像 1 Acer Aspire One A150-1672 Individual Key Replacement: 手順 5、 2の画像 2
    • Two ends need to be unhooked. They are located at the top and bottom of the key on the right side.
    • Using the Spudger, push the small, clear-colored end of the hinge out of the hook.
  6. Acer Aspire One A150-1672 Individual Key Replacement: 手順 6、 2の画像 1 Acer Aspire One A150-1672 Individual Key Replacement: 手順 6、 2の画像 2
    • Using the Blue Plastic Opening Tool, push the plastic hinge to the left to detach the hinge after the ends on the right are detached.
    • Remove the plastic hinge by pulling the plastic hinge upwards.
終わりに
作成者
4人の作成者と共同で作成されました。
Vivianna
メンバー登録日: 10/30/16
101 ポイント
1ガイドが承認済み
チーム
Baylor, Team 4-3, Williams Fall 2016 Baylor, Team 4-3, Williams Fall 2016人のメンバー
BU-WILLIAMS-F16S4G3
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 263
