メインコンテンツにスキップ
Acer Aspire One A150-1672 Front-facing Camera Replacement
必要な工具と部品
  1. Acer Aspire One A150-1672 Front-facing Camera Replacement, Front-facing Camera: 手順 1、 2の画像 1 Acer Aspire One A150-1672 Front-facing Camera Replacement, Front-facing Camera: 手順 1、 2の画像 2
    • With your fingers, remove 6 rubber coverings located at the edges of screen. The rubber coverings are held in place with a small amount of adhesive, but you should be able to peel them off easily.
    • There are 4 coverings on the top (circular shaped) and 2 on the bottom (half-oval shaped).
  2. Acer Aspire One A150-1672 Front-facing Camera Replacement: 手順 2、 2の画像 1 Acer Aspire One A150-1672 Front-facing Camera Replacement: 手順 2、 2の画像 2
    • Using a Phillips #1 screwdriver, unscrew the six 5.2mm screws in the places where the rubber coverings were located.
  3. Acer Aspire One A150-1672 Front-facing Camera Replacement: 手順 3、 2の画像 1 Acer Aspire One A150-1672 Front-facing Camera Replacement: 手順 3、 2の画像 2
    • Slide the spudger between the thin gap located between the white and pink plastic casing at the top.
    • Move the spudger from the right side to the left to detach the white plastic frame from the pink plastic casing.
    • Remove the white frame by pulling it towards yourself.
    • It may take considerable force to initially slide the spudger between the white and pink parts of the casing.
  4. Acer Aspire One A150-1672 Front-facing Camera Replacement: 手順 4、 1の画像 1
    • At the top of the display screen, pull the brown connector towards the right with your right hand while holding on to the black piece of electrical tape next to the white connector with your left hand to disconnect the two connectors from each other.
    • Gently pull the display screen towards you to more easily access the cable behind the screen.
  5. Acer Aspire One A150-1672 Front-facing Camera Replacement: 手順 5、 2の画像 1 Acer Aspire One A150-1672 Front-facing Camera Replacement: 手順 5、 2の画像 2
    • Use the spudger to detach the piece of tape from the camera by sliding it between the camera and tape.
    • Pull the camera towards you to remove it.
終わりに
作成者
4人の作成者と共同で作成されました。
Connor Watkins
メンバー登録日: 10/30/16
261 ポイント
2のガイドは作成済み
チーム
Baylor, Team 4-3, Williams Fall 2016 Baylor, Team 4-3, Williams Fall 2016人のメンバー
BU-WILLIAMS-F16S4G3
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 374
