メインコンテンツにスキップ
Acer Aspire One A150-1570 Internal Wireless Card Replacement
必要な工具と部品
  1. Acer Aspire One A150-1570 Internal Wireless Card Replacement, Keyboard: 手順 1、 1の画像 1
    • Flip device over so that the battery is farthest from you.
    • Identify the switch on the upper left corner and push it left to be in "unlocked" position.
  2. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 2、 2の画像 1 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 2、 2の画像 2
    • Identify the latch on the upper right hand corner. Drag and hold the latch to the right.
    • Pull the battery out.
  3. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 3、 2の画像 1 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 3、 2の画像 2
    • Now flip device back over to show the keyboard.
    • Locate the three tabs at the top of the keyboard.
  4. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 4、 3の画像 1 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 4、 3の画像 2 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 4、 3の画像 3
    • Start on the top-right and use the spudger to push off the tab from the keyboard.
    • Move to the middle tab while still holding the right side up so the tab doesn't fall back into place.
    • Continue to hold up keyboard while disconnecting the last tab.
    • DO NOT lift keyboard yet. This will be addressed in the next step.
  5. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 5、 3の画像 1 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 5、 3の画像 2 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 5、 3の画像 3
    • Here you can see that the keyboard is still attached to the device.
    • Use the Spudger to lift the ZIF (Zero Insertion Force) to release the keyboard ribbon.
    • Once tab is lifted, the keyboard ribbon should come right out.
  6. Acer Aspire One A150-1570 Internal Wireless Card Replacement, Internal Wireless Card: 手順 6、 1の画像 1
    • Close and flip the device over so you can have a good view of all the screws.
    • Locate and remove the three 3.9mm screws where the battery was removed from.
    • Locate and and remove the two 5.8mm screws located underneath the bumpers.
    • Locate and remove the three 5.8mm remaining screws at the top of the device.
  7. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 7、 3の画像 1 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 7、 3の画像 2 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 7、 3の画像 3
    • Flip and reopen device to where you can view the internal panel.
    • Locate the ZIF connecting the mouse panel to the motherboard.
    • Flip up the black plastic hinge and carefully pull out the ZIF connector.
  8. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 8、 1の画像 1
    • Locate and remove all five 4.7mm black screws.
    • Locate and remove the one 4.3mm silver screw.
  9. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 9、 2の画像 1 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 9、 2の画像 2
    • Pick a corner and slowly lift up the panel while running your finger underneath to pop off the seals.
    • Make sure to move slowly. You do not want to crack the plastic from being to rough or moving to fast.
  10. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 10、 2の画像 1 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 10、 2の画像 2
    • Locate the internal wireless card.
    • Remove the one 3.9mm screw holding it down.
  11. Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 11、 3の画像 1 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 11、 3の画像 2 Acer Aspire One A150-1570 Internal Wireless Card Replacement: 手順 11、 3の画像 3
    • Carefully disconnect the black and white cable from the internal wireless card.
    • Pull the internal wireless card straight out.
終わりに
作成者
2人の作成者と共同で作成されました。
Briana Naranjo
メンバー登録日: 10/10/16
369 ポイント
3のガイドは作成済み
チーム
Sam Houston State, Team 12-5, Blackburne Fall 2016 Sam Houston State, Team 12-5, Blackburne Fall 2016人のメンバー
SHSU-BLACKBURNE-F16S12G5
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 11
今までの合計 331
