メインコンテンツにスキップ
Acer Aspire One 725-0845 Touchpad Replacement
必要な工具と部品
  1. Acer Aspire One 725-0845 Touchpad Replacement, Battery: 手順 1、 1の画像 1
    • Ensure the device is powered off by holding down the power button on the top left-hand side.
    • On a flat, level surface, flip the device over so that the back-plate is accessible.
  2. Acer Aspire One 725-0845 Touchpad Replacement: 手順 2、 3の画像 1 Acer Aspire One 725-0845 Touchpad Replacement: 手順 2、 3の画像 2 Acer Aspire One 725-0845 Touchpad Replacement: 手順 2、 3の画像 3
    • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
    • Simultaneously pull the battery out and away from the device.
  3. Acer Aspire One 725-0845 Touchpad Replacement, Back Plate: 手順 3、 3の画像 1 Acer Aspire One 725-0845 Touchpad Replacement, Back Plate: 手順 3、 3の画像 2 Acer Aspire One 725-0845 Touchpad Replacement, Back Plate: 手順 3、 3の画像 3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
    • Using your hands, slide the back-plate away from the center of the device and remove.
  4. Acer Aspire One 725-0845 Touchpad Replacement, Hard Drive: 手順 4、 2の画像 1 Acer Aspire One 725-0845 Touchpad Replacement, Hard Drive: 手順 4、 2の画像 2
    • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (9.0 mm) from the outward side of the hard drive.
  5. Acer Aspire One 725-0845 Touchpad Replacement: 手順 5、 1の画像 1
    • Using your hand, slide the hard drive away from the center of the device until it disconnects from the motherboard.
    • Carefully lift the outward side of the hard drive and place the drive on a clean, non-magnetic surface.
  6. Acer Aspire One 725-0845 Touchpad Replacement, Inner Frame: 手順 6、 3の画像 1 Acer Aspire One 725-0845 Touchpad Replacement, Inner Frame: 手順 6、 3の画像 2 Acer Aspire One 725-0845 Touchpad Replacement, Inner Frame: 手順 6、 3の画像 3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the six outside screws (7.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the seven inside screws (8.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the one inside screw (3.0 mm).
  7. Acer Aspire One 725-0845 Touchpad Replacement: 手順 7、 3の画像 1 Acer Aspire One 725-0845 Touchpad Replacement: 手順 7、 3の画像 2 Acer Aspire One 725-0845 Touchpad Replacement: 手順 7、 3の画像 3
    • Using your hands, slide the brown release tabs for the keyboard connection away from the center of the device.
    • Gently remove the keyboard connection by pulling away from the center of the device.
    • Lift the black locks for the touchpad connections into the upward position.
    • Gently remove the touchpad connections by pulling the purple tabs away from the locks.
  8. Acer Aspire One 725-0845 Touchpad Replacement: 手順 8、 3の画像 1 Acer Aspire One 725-0845 Touchpad Replacement: 手順 8、 3の画像 2 Acer Aspire One 725-0845 Touchpad Replacement: 手順 8、 3の画像 3
    • Flip the device over and open it.
    • Using the plastic opening tools, remove the cover/palm rest from the frame of the device.
  9. Acer Aspire One 725-0845 Touchpad Replacement, Keyboard: 手順 9、 2の画像 1 Acer Aspire One 725-0845 Touchpad Replacement, Keyboard: 手順 9、 2の画像 2
    • Using the JIS J1 Screwdriver Bit and Driver, remove the 17 screws (3.0 mm) from the back of the keyboard.
  10. Acer Aspire One 725-0845 Touchpad Replacement: 手順 10、 2の画像 1 Acer Aspire One 725-0845 Touchpad Replacement: 手順 10、 2の画像 2
    • Remove the keyboard by lifting up and away from the cover/palm rest. Be careful with the keyboard connection during this step.
    • To replace an individual key, remove the key from the keyboard using a plastic opening tool.
  11. Acer Aspire One 725-0845 Touchpad Replacement, Touchpad: 手順 11、 2の画像 1 Acer Aspire One 725-0845 Touchpad Replacement, Touchpad: 手順 11、 2の画像 2
    • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (7.0 mm) from touchpad buttons.
  12. Acer Aspire One 725-0845 Touchpad Replacement: 手順 12、 2の画像 1 Acer Aspire One 725-0845 Touchpad Replacement: 手順 12、 2の画像 2
    • On the cover/palm rest, lift the black locks for the touchpad buttons into the upward position.
    • Remove the connection for the touchpad buttons by gently pulling the purple tabs away from the locks.
    • Remove touchpad buttons by lifting them up and away from the cover/palm rest.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Joe Kendall
メンバー登録日: 02/15/17
346 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 8-3, Eyestone Spring 2017 USF Tampa, Team 8-3, Eyestone Spring 2017人のメンバー
USFT-EYESTONE-S17S8G3
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 18
今までの合計 1,384
