はじめに
The speakers are the sound source for the device. A damaged speaker or outdated driver will cause the device to produce unclear or no sound. If you have followed all the steps in the Troubleshooting Guide and found that you have a damaged or faulty speaker, this step-by-step guide will lead you through the process of removing the battery, back-plate, hard drive, cover/palm rest, and speakers.
必要な工具と部品
Ensure the device is powered off by holding down the power button on the top left-hand side.
On a flat, level surface, flip the device over so that the back-plate is accessible.
Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
Using your hands, slide the back-plate away from the center of the device and remove.
Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (9.0 mm) from the outward side of the hard drive.
Using the JIS J1 Screwdriver Bit and Driver, remove the six outside screws (7.0 mm).
Using the JIS J1 Screwdriver Bit and Driver, remove the seven inside screws (8.0 mm).
Using the JIS J1 Screwdriver Bit and Driver, remove the one inside screw (3.0 mm).
Using your hands, slide the brown release tabs for the keyboard connection away from the center of the device.
Gently remove the keyboard connection by pulling away from the center of the device.
Lift the black locks for the touchpad connections into the upward position.
Gently remove the touchpad connections by pulling the purple tabs away from the locks.
Lift the black locks for the indicator light connections into the upward position.
Remove the indicator light connection by gently pulling the purple tabs away from the locks.
ある他の人がこのガイドを完成しました。
