メインコンテンツにスキップ
Acer Aspire One 722 Hard Drive Replacement
必要な工具と部品
  1. Acer Aspire One 722 Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Hard Drive Replacement: 手順 2、 1の画像 1
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Hard Drive Replacement: 手順 3、 1の画像 1
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Hard Drive Replacement: 手順 4、 2の画像 1 Acer Aspire One 722 Hard Drive Replacement: 手順 4、 2の画像 2
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Hard Drive Replacement: 手順 5、 1の画像 1
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
  6. Acer Aspire One 722 Hard Drive Replacement, Hard Drive: 手順 6、 1の画像 1
    • Ensure the Laptop is powered down with the battery removed prior to beginning.
    • With the battery cavity facing away from you, use the Phillips #0 to remove the center screw which secures the backplate.
    • Make sure to keep track of these screws for reassembly.
  7. Acer Aspire One 722 Hard Drive Replacement: 手順 7、 1の画像 1
    • Gently lift up and pull away the backplate from the chassis to remove.
  8. Acer Aspire One 722 Hard Drive Replacement: 手順 8、 1の画像 1
    • With the backplate removed, locate the HDD in the upper left corner of the device.
    • Use the Phillips #0 screwdriver to remove the four corner screws securing the HDD to the chassis.
  9. Acer Aspire One 722 Hard Drive Replacement: 手順 9、 2の画像 1 Acer Aspire One 722 Hard Drive Replacement: 手順 9、 2の画像 2
    • Gently lift and secure the HDD with one hand and carefully remove the SATA and power connections with your other hand.
    • Once removed, store the replaced drive in an anti-static environment to ensure its integrity.
  10. Acer Aspire One 722 Hard Drive Replacement: 手順 10、 3の画像 1 Acer Aspire One 722 Hard Drive Replacement: 手順 10、 3の画像 2 Acer Aspire One 722 Hard Drive Replacement: 手順 10、 3の画像 3
    • With your replacement HDD in hand, reseat the power and SATA cables removed from the previous drive.
    • The plugs are diffrent sizes so there is no fear of mixing them up
    • With the cables attached, align the four mounting points in the corner of the drive with the chassis and reseat the four Phillips #0 screws that were removed earlier.
終わりに
To reassemble your device, follow these instructions in reverse order., taking special care in replacing the back cover. and battery.
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Christian Barboza
メンバー登録日: 10/25/15
818 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015人のメンバー
UMASSD-GULBRANDSEN-F15S5G6
3 メンバー
10のガイドは作成済み
コメント 1 件
لا يعمل بعد انسطاب عليه ماء ما الحل
Belql Sayes - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 41
今までの合計 5,537
