メインコンテンツにスキップ
Acer Aspire One 532h-2806 Screen Replacement
必要な工具と部品
  1. Acer Aspire One 532h-2806 Screen Replacement, Screen: 手順 1、 2の画像 1 Acer Aspire One 532h-2806 Screen Replacement, Screen: 手順 1、 2の画像 2
    • Turn the device off before beginning any replacements.
    • Locate the two circular black stickers at the bottom corners of the laptop screen.
    • Remove the stickers.
    • Two 6mm Phillips Screws should now be visible.
  2. Acer Aspire One 532h-2806 Screen Replacement: 手順 2、 2の画像 1 Acer Aspire One 532h-2806 Screen Replacement: 手順 2、 2の画像 2
    • Use a Phillips #0 Screwdriver to remove the two 6mm screws from the screen.
  3. Acer Aspire One 532h-2806 Screen Replacement: 手順 3、 2の画像 1 Acer Aspire One 532h-2806 Screen Replacement: 手順 3、 2の画像 2
    • Using the opener tool, remove the plastic cover, surrounding the screen.
    • It is normal to hear clicking sounds as the plastic cover is removed.
  4. Acer Aspire One 532h-2806 Screen Replacement: 手順 4、 3の画像 1 Acer Aspire One 532h-2806 Screen Replacement: 手順 4、 3の画像 2 Acer Aspire One 532h-2806 Screen Replacement: 手順 4、 3の画像 3
    • Remove the four 6mm Phillips screws surrounding the screen.
    • These are holding the screen in place. After the screws are removed, the screen should remove itself from the plastic outer cover.
  5. Acer Aspire One 532h-2806 Screen Replacement: 手順 5、 1の画像 1
    • Peel back the fuss cable from the outer laptop plastic cover.
    • Be careful, not to yank or rip the cable, it should gently peel back.
  6. Acer Aspire One 532h-2806 Screen Replacement: 手順 6、 1の画像 1
    • Locate the ZIF (zero insertion force) Cable.
    • Peel back any tape if necessary
    • Carefully unplug it.
    • Do not pull hard, it should remove itself easily.
  7. Acer Aspire One 532h-2806 Screen Replacement: 手順 7、 2の画像 1 Acer Aspire One 532h-2806 Screen Replacement: 手順 7、 2の画像 2
    • Remove the two 6mm screws on each side of the screen with a Phillips #0 screwdriver.
  8. Acer Aspire One 532h-2806 Screen Replacement: 手順 8、 3の画像 1 Acer Aspire One 532h-2806 Screen Replacement: 手順 8、 3の画像 2 Acer Aspire One 532h-2806 Screen Replacement: 手順 8、 3の画像 3
    • Remove the screen.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Julie Paula
メンバー登録日: 01/12/17
527 ポイント
4のガイドは作成済み
チーム
Oakland University, Team 2-4, Ruskiewicz Winter 2017 Oakland University, Team 2-4, Ruskiewicz Winter 2017人のメンバー
OAK-RUSKIEWICZ-W17S2G4
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 277
