メインコンテンツにスキップ
Acer Aspire One 532h-2527 Keyboard Replacement
必要な工具と部品
  1. Acer Aspire One 532h-2527 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Press the power button to turn off the netbook.
  2. Acer Aspire One 532h-2527 Keyboard Replacement: 手順 2、 1の画像 1
    • Place the netbook bottom-side-up on a flat surface.
    • Locate the unlock latch on the top right corner of the back.
  3. Acer Aspire One 532h-2527 Keyboard Replacement: 手順 3、 1の画像 1
    • To unlock the battery, slide the lock latch in the direction indicated by the unlocking icon. You should see the orange indicator which means that the latch is unlocked.
  4. Acer Aspire One 532h-2527 Keyboard Replacement: 手順 4、 3の画像 1 Acer Aspire One 532h-2527 Keyboard Replacement: 手順 4、 3の画像 2 Acer Aspire One 532h-2527 Keyboard Replacement: 手順 4、 3の画像 3
    • On the opposite side, slide and hold the release latch.
    • Gently slide the battery out.
  5. Acer Aspire One 532h-2527 Keyboard Replacement, Keyboard: 手順 5、 1の画像 1
    • Locate the three latches along the top crevice along the top rows of keys and the plastic boarder.
  6. Acer Aspire One 532h-2527 Keyboard Replacement: 手順 6、 3の画像 1 Acer Aspire One 532h-2527 Keyboard Replacement: 手順 6、 3の画像 2 Acer Aspire One 532h-2527 Keyboard Replacement: 手順 6、 3の画像 3
    • Using the metal spudger, gently pry each tab releasing the keyboard. Make sure as you move to each new one that the previous one does not reset itself.
  7. Acer Aspire One 532h-2527 Keyboard Replacement: 手順 7、 1の画像 1
    • Check for tabs on the side of the keyboard.
    • If there are no tabs lift the top of the keyboard.
  8. Acer Aspire One 532h-2527 Keyboard Replacement: 手順 8、 3の画像 1 Acer Aspire One 532h-2527 Keyboard Replacement: 手順 8、 3の画像 2 Acer Aspire One 532h-2527 Keyboard Replacement: 手順 8、 3の画像 3
    • Locate the sticker-like connecter on the back of the keyboard. Carefully unplug it.
  9. Acer Aspire One 532h-2527 Keyboard Replacement: 手順 9、 2の画像 1 Acer Aspire One 532h-2527 Keyboard Replacement: 手順 9、 2の画像 2
    • Remove keyboard.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jair Burgos
メンバー登録日: 09/15/16
425 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 11-6, Blackwell Fall 2016 USF Tampa, Team 11-6, Blackwell Fall 2016人のメンバー
USFT-BLACKWELL-F16S11G6
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 705
