メインコンテンツにスキップ
Acer Aspire One 532h-2527 Hard Disk Drive Replacement
必要な工具と部品
  1. Acer Aspire One 532h-2527 Hard Disk Drive Replacement, Battery: 手順 1、 1の画像 1
    • Press the power button to turn off the netbook.
  2. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 手順 2、 1の画像 1
    • Place the netbook bottom-side-up on a flat surface.
    • Locate the unlock latch on the top right corner of the back.
  3. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 手順 3、 1の画像 1
    • To unlock the battery, slide the lock latch in the direction indicated by the unlocking icon. You should see the orange indicator which means that the latch is unlocked.
  4. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 手順 4、 3の画像 1 Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 手順 4、 3の画像 2 Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 手順 4、 3の画像 3
    • On the opposite side, slide and hold the release latch.
    • Gently slide the battery out.
  5. Acer Aspire One 532h-2527 Hard Disk Drive Replacement, Back Plate: 手順 5、 1の画像 1
    • Use a #0 Phillips screwdriver to remove the three 6mm screws from the larger back plate.
  6. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 手順 6、 1の画像 1
    • Use the plastic opening tool on the recessed notch at the bottom of the larger plate to gently lift the plate.
  7. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 手順 7、 1の画像 1
    • Once the plate becomes unhinged, gently rotate the plate to take it off of the device.
  8. Acer Aspire One 532h-2527 Hard Disk Drive Replacement, Hard Disk Drive: 手順 8、 1の画像 1
    • Locate the HDD after the back plate is removed. It will be the large rectangle that takes up most of the space.
  9. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 手順 9、 2の画像 1 Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 手順 9、 2の画像 2
    • Gently press down on the HDD and slide it to the left as far as it will go.
  10. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 手順 10、 2の画像 1 Acer Aspire One 532h-2527 Hard Disk Drive Replacement: 手順 10、 2の画像 2
    • Grab the edges of the HDD, slightly rotate it, and gently pull it out.
終わりに
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Erica Romero
メンバー登録日: 09/15/16
481 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 11-6, Blackwell Fall 2016 USF Tampa, Team 11-6, Blackwell Fall 2016人のメンバー
USFT-BLACKWELL-F16S11G6
3 メンバー
12のガイドは作成済み
コメント 1 件
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 17
今までの合計 1,667
