メインコンテンツにスキップ
Acer Aspire ES1-711-P1UV Screen Replacement
必要な工具と部品
  1. Acer Aspire ES1-711-P1UV Screen Replacement, Battery: 手順 1、 1の画像 1
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Screen Replacement: 手順 2、 1の画像 1
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Screen Replacement: 手順 3、 1の画像 1
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Screen Replacement: 手順 4、 1の画像 1
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
  5. Acer Aspire ES1-711-P1UV Screen Replacement, Screen: 手順 5、 2の画像 1 Acer Aspire ES1-711-P1UV Screen Replacement, Screen: 手順 5、 2の画像 2
    • Place the laptop on a flat surface and open it to see the screen.
    • Using your fingers or a plastic opening tool, pry open the bezel that holds the screen in place.
  6. Acer Aspire ES1-711-P1UV Screen Replacement: 手順 6、 3の画像 1 Acer Aspire ES1-711-P1UV Screen Replacement: 手順 6、 3の画像 2 Acer Aspire ES1-711-P1UV Screen Replacement: 手順 6、 3の画像 3
    • Use the Phillips #0 screwdriver to remove the fourteen 5mm screws around the screen.
    • Use the Phillips #0 screwdriver to remove the four 4mm screws holding in the screen.
    • Before unscrewing the screen, place a paper on the keyboard to protect the screen from scratches.
  7. Acer Aspire ES1-711-P1UV Screen Replacement: 手順 7、 2の画像 1 Acer Aspire ES1-711-P1UV Screen Replacement: 手順 7、 2の画像 2
    • With the screen on the paper, detach the Zero Insertion Force (ZIF) connector attaching the screen to the video cable inside of the front cover.
    • To remove the ZIF use your finger to flip up the top cover and gently pull the cable out.
    • Be sure to pry open the hinged flap not the connector socket
    • Gently remove the screen from laptop.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Camille Ingham
メンバー登録日: 03/22/18
418 ポイント
2のガイドは作成済み
チーム
Sam Houston State, Team S17-G3, Blackburne Winter 2018 Sam Houston State, Team S17-G3, Blackburne Winter 2018人のメンバー
SHSU-BLACKBURNE-W18S17G3
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 823
