メインコンテンツにスキップ
Acer Aspire ES1-512-C80E Keyboard Replacement
必要な工具と部品
  1. Acer Aspire ES1-512-C80E Keyboard Replacement, Back Cover: 手順 1、 1の画像 1
    • Place the device upside down on a flat surface.
    • Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
  2. Acer Aspire ES1-512-C80E Keyboard Replacement: 手順 2、 3の画像 1 Acer Aspire ES1-512-C80E Keyboard Replacement: 手順 2、 3の画像 2 Acer Aspire ES1-512-C80E Keyboard Replacement: 手順 2、 3の画像 3
    • Pry around the edges with a spudger to remove the back cover.
    • The two hinges on the back require additional force to be popped open.
  3. Acer Aspire ES1-512-C80E Keyboard Replacement, Keyboard: 手順 3、 3の画像 1 Acer Aspire ES1-512-C80E Keyboard Replacement, Keyboard: 手順 3、 3の画像 2 Acer Aspire ES1-512-C80E Keyboard Replacement, Keyboard: 手順 3、 3の画像 3
    • The keyboard is the silver piece located by itself on the upper half of the laptop.
    • Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
    • Using a spudger, go around the edges and pry off the keyboard.
    • All black clips will have to be removed before the keyboard can be removed.
  4. Acer Aspire ES1-512-C80E Keyboard Replacement: 手順 4、 3の画像 1 Acer Aspire ES1-512-C80E Keyboard Replacement: 手順 4、 3の画像 2 Acer Aspire ES1-512-C80E Keyboard Replacement: 手順 4、 3の画像 3
    • Remove the ribbon cable connection from the keyboard.
    • Peel back the two pieces of tape to separate the keyboard.
    • Remove the keyboard from under the plastic covering.
    • Remove the silver plate back cover of the keyboard from the bottom base.
  5. Acer Aspire ES1-512-C80E Keyboard Replacement: 手順 5、 2の画像 1 Acer Aspire ES1-512-C80E Keyboard Replacement: 手順 5、 2の画像 2
    • Remove the large silver plate from the keyboard.
    • You can not remove the silver backing with the attached wire from the back of the keyboard.
  6. Acer Aspire ES1-512-C80E Keyboard Replacement: 手順 6、 1の画像 1
    • The keyboard is removed and ready to be replaced.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Robert Creighton
メンバー登録日: 10/31/19
682 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G8, Barthe Fall 2019 UMass Dartmouth, Team S2-G8, Barthe Fall 2019人のメンバー
UMASSD-BARTHE-F19S2G8
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 19
今までの合計 1,185
