はじめに
You may need to replace the disk drive in your Acer Aspire ES1-512-C80E if it does not function properly. To access the disk drive, the back cover of the device will need to be removed. The process of replacing the disk drive should take between 10-20 minutes.
必要な工具と部品
Place the device upside down on a flat surface.
Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
Using a spudger, go around the edges and pry off the keyboard.
To reassemble your device, follow the steps in reverse order.
ある他の人がこのガイドを完成しました。
