メインコンテンツにスキップ
Acer Aspire E5-571P-55TL RAM Replacement
必要な工具と部品
  1. Acer Aspire E5-571P-55TL RAM Replacement, Battery: 手順 1、 1の画像 1
    • Make sure that laptop is turned off.
    • Turn the laptop upside down with the battery facing you.
  2. Acer Aspire E5-571P-55TL RAM Replacement: 手順 2、 1の画像 1
    • Place the Spudger into the battery lock and slide it to the left until you hear the battery unlock.
  3. Acer Aspire E5-571P-55TL RAM Replacement: 手順 3、 2の画像 1 Acer Aspire E5-571P-55TL RAM Replacement: 手順 3、 2の画像 2
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571P-55TL RAM Replacement, Keyboard: 手順 4、 2の画像 1 Acer Aspire E5-571P-55TL RAM Replacement, Keyboard: 手順 4、 2の画像 2
    • Using a Phillips #0 screwdriver, remove each of the eighteen 8 mm screws from the bottom of the laptop.
  5. Acer Aspire E5-571P-55TL RAM Replacement: 手順 5、 3の画像 1 Acer Aspire E5-571P-55TL RAM Replacement: 手順 5、 3の画像 2 Acer Aspire E5-571P-55TL RAM Replacement: 手順 5、 3の画像 3
    • Carefully place your fingers underneath the top of the keyboard just below the screen.
    • Pull upwards until you can hear the keyboard click out of place.
    • Continue around the entire laptop, carefully pulling the keyboard and palm rest assembly slightly from the frame to reveal the ribbon connectors.
    • Don't pull the keyboard off the frame yet because it's attached by ribbon connectors.
    • After the keyboard is detached, unplug each of the three ribbon cables and remove the keyboard and palm rest assembly.
  6. Acer Aspire E5-571P-55TL RAM Replacement, CPU Fan: 手順 6、 2の画像 1 Acer Aspire E5-571P-55TL RAM Replacement, CPU Fan: 手順 6、 2の画像 2
    • Before replacing the CPU fan, you'll have to remove the network card found below the fan.
    • Using a Philips #0 screwdriver, remove the two 3 mm screws from the corners of the Wi-Fi card.
    • Carefully lift the network card from it's slot, and disconnect the two coaxial cables.
  7. Acer Aspire E5-571P-55TL RAM Replacement: 手順 7、 2の画像 1 Acer Aspire E5-571P-55TL RAM Replacement: 手順 7、 2の画像 2
    • The CPU fan can be found in the upper left corner of the laptop.
    • Using a Phillips #0 screwdriver, remove the two 4.5 mm screws from the fan.
  8. Acer Aspire E5-571P-55TL RAM Replacement: 手順 8、 2の画像 1 Acer Aspire E5-571P-55TL RAM Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use tweezers to safely remove the fan plug from the motherboard. To remove the plug, gently push left.
  9. Acer Aspire E5-571P-55TL RAM Replacement: 手順 9、 1の画像 1
    • Make sure that all fan wires are disconnected from the board.
    • Lift the curved end of the fan, and safely remove it.
  10. Acer Aspire E5-571P-55TL RAM Replacement, Hard Drive: 手順 10、 1の画像 1
    • Using a Phillips #0 screwdriver, remove the two 8 mm screws holding the hard drive carriage in place.
  11. Acer Aspire E5-571P-55TL RAM Replacement: 手順 11、 2の画像 1 Acer Aspire E5-571P-55TL RAM Replacement: 手順 11、 2の画像 2
    • Carefully unplug the ribbon cable running across the hard drive carriage and place it to the side.
    • Remove the hard drive by sliding it to your right, away from the motherboard, next pull the hard drive towards yourself and away from the laptop.
  12. Acer Aspire E5-571P-55TL RAM Replacement: 手順 12、 1の画像 1
    • Once again using a Phillips #0 screwdriver, remove the two 3 mm screws highlighted on each side of the hard drive case.
    • Open the hard drive case to replace the hard drive.
  13. Acer Aspire E5-571P-55TL RAM Replacement, Motherboard: 手順 13、 2の画像 1 Acer Aspire E5-571P-55TL RAM Replacement, Motherboard: 手順 13、 2の画像 2
    • With a Phillips #0 screwdriver, remove the two 4 mm screws from the motherboard.
  14. Acer Aspire E5-571P-55TL RAM Replacement: 手順 14、 3の画像 1 Acer Aspire E5-571P-55TL RAM Replacement: 手順 14、 3の画像 2 Acer Aspire E5-571P-55TL RAM Replacement: 手順 14、 3の画像 3
    • Carefully disconnect the speaker connection to the motherboard.
  15. Acer Aspire E5-571P-55TL RAM Replacement: 手順 15、 3の画像 1 Acer Aspire E5-571P-55TL RAM Replacement: 手順 15、 3の画像 2 Acer Aspire E5-571P-55TL RAM Replacement: 手順 15、 3の画像 3
    • The last connection to the motherboard is the screen. Gently disconnect the cable from the motherboard.
  16. Acer Aspire E5-571P-55TL RAM Replacement: 手順 16、 1の画像 1
    • Lift the motherboard up from the top right corner, and then pull it right to release it from the case.
  17. Acer Aspire E5-571P-55TL RAM Replacement, RAM: 手順 17、 2の画像 1 Acer Aspire E5-571P-55TL RAM Replacement, RAM: 手順 17、 2の画像 2
    • Flipe the motherboard over.
    • The RAM is locked into place by two clips.
    • Using the tips of each index finger, gently pull the clips away from the RAM module.
  18. Acer Aspire E5-571P-55TL RAM Replacement: 手順 18、 1の画像 1
    • When the RAM stick is released, slide it out of the slot.
終わりに
作成者
3人の作成者と共同で作成されました。
Max Piekos
メンバー登録日: 03/23/22
459 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team B-1, Gurgel Spring 2022 UMass Dartmouth, Team B-1, Gurgel Spring 2022人のメンバー
UMASSD-GURGEL-S22SBG1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 412
