メインコンテンツにスキップ
Acer Aspire E5-571P-55TL Hard Drive Replacement
必要な工具と部品
  1. Acer Aspire E5-571P-55TL Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Make sure that laptop is turned off.
    • Turn the laptop upside down with the battery facing you.
  2. Acer Aspire E5-571P-55TL Hard Drive Replacement: 手順 2、 1の画像 1
    • Place the Spudger into the battery lock and slide it to the left until you hear the battery unlock.
  3. Acer Aspire E5-571P-55TL Hard Drive Replacement: 手順 3、 2の画像 1 Acer Aspire E5-571P-55TL Hard Drive Replacement: 手順 3、 2の画像 2
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571P-55TL Hard Drive Replacement, Keyboard: 手順 4、 2の画像 1 Acer Aspire E5-571P-55TL Hard Drive Replacement, Keyboard: 手順 4、 2の画像 2
    • Using a Phillips #0 screwdriver, remove each of the eighteen 8 mm screws from the bottom of the laptop.
  5. Acer Aspire E5-571P-55TL Hard Drive Replacement: 手順 5、 3の画像 1 Acer Aspire E5-571P-55TL Hard Drive Replacement: 手順 5、 3の画像 2 Acer Aspire E5-571P-55TL Hard Drive Replacement: 手順 5、 3の画像 3
    • Carefully place your fingers underneath the top of the keyboard just below the screen.
    • Pull upwards until you can hear the keyboard click out of place.
    • Continue around the entire laptop, carefully pulling the keyboard and palm rest assembly slightly from the frame to reveal the ribbon connectors.
    • Don't pull the keyboard off the frame yet because it's attached by ribbon connectors.
    • After the keyboard is detached, unplug each of the three ribbon cables and remove the keyboard and palm rest assembly.
  6. Acer Aspire E5-571P-55TL Hard Drive Replacement, Hard Drive: 手順 6、 1の画像 1
    • Using a Phillips #0 screwdriver, remove the two 8 mm screws holding the hard drive carriage in place.
  7. Acer Aspire E5-571P-55TL Hard Drive Replacement: 手順 7、 2の画像 1 Acer Aspire E5-571P-55TL Hard Drive Replacement: 手順 7、 2の画像 2
    • Carefully unplug the ribbon cable running across the hard drive carriage and place it to the side.
    • Remove the hard drive by sliding it to your right, away from the motherboard, next pull the hard drive towards yourself and away from the laptop.
  8. Acer Aspire E5-571P-55TL Hard Drive Replacement: 手順 8、 1の画像 1
    • Once again using a Phillips #0 screwdriver, remove the two 3 mm screws highlighted on each side of the hard drive case.
    • Open the hard drive case to replace the hard drive.
終わりに
作成者
3人の作成者と共同で作成されました。
Zebediah Perkins
メンバー登録日: 03/27/22
112 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team B-1, Gurgel Spring 2022 UMass Dartmouth, Team B-1, Gurgel Spring 2022人のメンバー
UMASSD-GURGEL-S22SBG1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 178
