メインコンテンツにスキップ
Acer Aspire E5-571 WiFi Replacement
必要な工具と部品
  1. Acer Aspire E5-571 WiFi Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 WiFi Replacement: 手順 2、 1の画像 1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 WiFi Replacement: 手順 3、 1の画像 1
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 WiFi Replacement, Keyboard: 手順 4、 1の画像 1
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 WiFi Replacement: 手順 5、 3の画像 1 Acer Aspire E5-571 WiFi Replacement: 手順 5、 3の画像 2 Acer Aspire E5-571 WiFi Replacement: 手順 5、 3の画像 3
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips. Do not remove the keyboard until told to do so.
  6. Acer Aspire E5-571 WiFi Replacement: 手順 6、 2の画像 1 Acer Aspire E5-571 WiFi Replacement: 手順 6、 2の画像 2
    • Carefully flip up the white hinge. Then, detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
  7. Acer Aspire E5-571 WiFi Replacement, WiFi: 手順 7、 1の画像 1
    • Locate the WiFi card on the motherboard.
  8. Acer Aspire E5-571 WiFi Replacement: 手順 8、 2の画像 1 Acer Aspire E5-571 WiFi Replacement: 手順 8、 2の画像 2
    • Locate the two antenna cables shown.
    • Using a plastic opening tool, remove both antenna cables from the WiFi card by gently prying them up.
    • Black on left. White on right.
  9. Acer Aspire E5-571 WiFi Replacement: 手順 9、 3の画像 1 Acer Aspire E5-571 WiFi Replacement: 手順 9、 3の画像 2 Acer Aspire E5-571 WiFi Replacement: 手順 9、 3の画像 3
    • Remove this 3 mm Phillips #0 screw and the WiFi card should pop up.
    • Make sure antenna cables are removed before removing the screw.
    • Gently lift WiFi card off of the motherboard.
終わりに
9 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
daniel sawyer
メンバー登録日: 08/23/15
2,566 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 4-2, Meier Fall 2015 USF Tampa, Team 4-2, Meier Fall 2015人のメンバー
USFT-MEIER-F15S4G2
3 メンバー
5のガイドは作成済み
7 件のコメント
Very well done - thank you!
glgsolutions - 返信
np. im glad it worked for you. could you post the exact model you have and was there anything I missed?
daniel sawyer -
Great guide. I would just like to mention a difference I found. My laptop had white connectors and the hinged lock latch was black. So I guess all assemblies aren’t identical. Also, the large connector for the keyboard did not have a locking latch. My model is an E5-571P manufactured 2014/09/15.
Dan O - 返信
Hi, I want faster Wifi. Which Wifi card do I need to replace for a Acer Aspire e15 e5-571-58E6?
Patrizia Barberio - 返信
Hi I just bought an upgrade, so I’ll tell you which one I got and if it worked when I get it in the mail in a few weeks.
Matt -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 27
今までの合計 7,510
